I’ve just created a new cConsole Torizon project, using Torizon IDE Extension v2.5.2.
I’m able to use some of the pre-built tasks (check-deps, build-debug-arm64, try-update-template, …).
Now I need to build the release artifact (i.e., the container image with my application), and pushing it to my private container registry. I use Azure Container Registry (instead of Dockerhub).
I run create-production-image task and I must fill-in some parameters, but it’s not clear to me how should I use the parameters:
docker_registrydocker_login
In my idea, docker_registry should be my registry (i.e., <organization_name>.azurecr.io for ACR), and docker_login should be the the identity who has the rights to push the image into the registry.
But the script createDockerComposeProduction.ps1 uses the above parameters in weird way.
I see the following lines:
$env:LOCAL_REGISTRY="$($localRegistry):5002"
$env:TAG="$tag"
if ([string]::IsNullOrEmpty($registry)) {
$env:DOCKER_LOGIN="$dockerLogin"
} else {
$env:DOCKER_LOGIN="$registry/$dockerLogin"
and so if docker_registry is not empty, docker_registry and docker_login are concatenated.
And so I get
Pushing it <organization_name>.azurecr.io/docker_login/tcb.packageName:docker_tag
but this is wrong for Azure Container Registry, because docker_login must not be included in the link.
The right link is
Pushing it <organization_name>.azurecr.io/tcb.packageName:docker_tag
I changed the scrip createDockerComposeProduction.ps1 setting
$env:DOCKER_LOGIN="$registry"
and in this way everything is of with Azure Container Registry.
Do you think that the default script can be changed so that ACR can work out of the box?
