After a Docker Desktop update on Win10 (-> Docker version 4.19.0 build 106363 → newest version available today), Torizon IDE backend is not able to access docker anymore.
I am running VSCode Toradex Torizon Support (Early Access v1.6.6)
The OUTPUT message on VSCode shows:
[04-22 07:31:31.997] Initializing Torizon Extension
[04-22 07:31:32.080] Checking system setup...
[04-22 07:31:32.081] Docker seem to not be enabled for current user, this will prevent many of the features of Torizon extension from working.
You may add your user to the docker group or run the Torizon IDE backend with an account that is part of that group.
[04-22 07:31:32.083] Checking Moses ...
[04-22 07:31:32.119] Starting backend local instance running on port 5001
[04-22 07:31:48.112] Torizon Backend version 1.0.0 API version: 1.1.7
[04-22 07:31:48.113] Torizon IDE backend started
[04-22 07:31:48.114] Checking Docker ...
(the last action Checking Docker
is lasting forever).
The message suggests a group issue but I checked that user torizon
is indeed part of the docker
group:
torizon@docker-desktop:~$ cat /etc/group |grep torizon
sudo:x:27:torizon
torizon:x:1000:
docker:x:0:torizon
The Torizon IDE backend process log shows :
INFO:root:REST -> /api/version/docker
DEBUG:connexion.apis.flask_api:Getting data and status code
DEBUG:connexion.decorators.parameter:Function Arguments: []
DEBUG:docker.utils.config:Trying paths: ['/home/torizon/.docker/config.json', '/home/torizon/.dockercfg']
DEBUG:docker.utils.config:No config file found
ERROR:root:docker version
File "urllib3/connectionpool.py", line 699, in urlopen
File "urllib3/connectionpool.py", line 394, in _make_request
File "http/client.py", line 1285, in request
File "http/client.py", line 1331, in _send_request
File "http/client.py", line 1280, in endheaders
File "http/client.py", line 1040, in _send_output
File "http/client.py", line 980, in send
File "docker/transport/unixconn.py", line 43, in connect
PermissionError: [Errno 13] Permission denied
During handling of the above exception, another exception occurred:
File "requests/adapters.py", line 489, in send
File "urllib3/connectionpool.py", line 755, in urlopen
File "urllib3/util/retry.py", line 531, in increment
File "urllib3/packages/six.py", line 734, in reraise
urllib3.exceptions.ProtocolError: ('Connection aborted.', PermissionError(13, 'Permission denied'))
File "docker/api/client.py", line 214, in _retrieve_server_version
File "docker/api/daemon.py", line 181, in version
File "docker/utils/decorators.py", line 46, in inner
File "docker/api/client.py", line 237, in _get
File "requests/sessions.py", line 600, in get
File "requests/sessions.py", line 587, in request
File "requests/sessions.py", line 701, in send
File "requests/adapters.py", line 547, in send
requests.exceptions.ConnectionError: ('Connection aborted.', PermissionError(13, 'Permission denied'))
File "api.py", line 134, in version_docker_get
File "docker/client.py", line 96, in from_env
File "docker/client.py", line 45, in __init__
File "docker/api/client.py", line 197, in __init__
File "docker/api/client.py", line 221, in _retrieve_server_version
docker.errors.DockerException: Error while fetching server API version: ('Connection aborted.', PermissionError(13, 'Permission denied'))
ERROR:root:Error: 530 Local docker exception. Docker exception: Error while fetching server API version: ('Connection aborted.', PermissionError(13, 'Permission denied'))
ERROR:root:Exception: Docker exception: Error while fetching server API version: ('Connection aborted.', PermissionError(13, 'Permission denied'))
ERROR:root:Error while fetching server API version: ('Connection aborted.', PermissionError(13, 'Permission denied'))
INFO:root:REST <- /api/version/docker - 530
It confirms a permission issue. It seems moses
is looking at /home/torizon/.docker/config.json
, which indeed does not exist:
torizon@docker-desktop:~$ pwd
/home/torizon
torizon@docker-desktop:~$ ls -la
total 304528
drwxr-xr-x 1 torizon root 4096 May 22 07:31 .
drwxr-xr-x 1 root root 4096 Sep 17 2022 ..
drwxr-xr-x 3 torizon torizon 4096 May 19 16:12 .cache
drwxr-xr-x 2 torizon torizon 4096 May 19 16:11 .devcontainer
drwxr-xr-x 3 torizon torizon 4096 May 19 16:12 .dotnet
drwxr-xr-x 1 root root 4096 May 19 14:52 .gdb
-rw-r--r-- 1 root root 157 May 19 14:52 .gdbinit
-rw-r--r-- 1 torizon torizon 571 May 22 07:31 .gitconfig
drwxr-xr-x 3 torizon torizon 4096 May 19 16:12 .local
drwxrwxrwx 1 root root 4096 Dec 16 2021 .moses
drwxr-xr-x 2 torizon torizon 4096 May 19 16:11 .ssh
drwxr-xr-x 6 torizon torizon 4096 May 19 16:11 .vscode-server
drwxr-xr-x 3 torizon torizon 4096 May 19 16:11 .vscode-server-insiders
I can’t find my way out of this issue. Do you have some advice ?
Fabian
