My setup looks like this:
ARG IMAGE_TAG=2-bullseye
ARG TOOLCHAIN_ARCH=aarch64
ARG PKG_ARCH=arm64
ARG IMAGE_ARCH=linux/arm64
FROM torizon/debian-cross-toolchain-arm64:2-bullseye
ARG PKG_ARCH
ARG TOOLCHAIN_ARCH
RUN echo "dpkg --add-architecture $PKG_ARCH"
RUN dpkg --add-architecture "$PKG_ARCH"
RUN apt-get -y update && apt-get install -y --fix-missing \
cmake \
python-dev \
gcc \
make \
gcc \
binutils \
build-essential \
wget \
pkg-config \
libseccomp-dev:$PKG_ARCH \
libasound2-dev:$PKG_ARCH \
libsystemd-dev:$PKG_ARCH \
libssl-dev:$PKG_ARCH \
zlib1g-dev:$PKG_ARCH \
libgpiod-dev:$PKG_ARCH \
libgpiod2:$PKG_ARCH \
libspeex-dev:$PKG_ARCH \
libspeexdsp-dev:$PKG_ARCH \
libsrtp2-dev:$PKG_ARCH \
libgsm1-dev:$PKG_ARCH \
libsnmp-dev:$PKG_ARCH \
libgstreamer1.0-dev:$PKG_ARCH \
libgstreamer-plugins-base1.0-dev:$PKG_ARCH \
libgstreamer-plugins-bad1.0-dev:$PKG_ARCH \
libwebsockets-dev:$PKG_ARCH \
libgstrtspserver-1.0-dev:$PKG_ARCH \
libgstreamermm-1.0-dev:$PKG_ARCH \
&& apt-get clean && apt-get autoremove && rm -rf /var/lib/apt/lists/*
Here’s the build output:
Step 10/20 : RUN apt-get -y update && apt-get install -y --fix-missing cmake python-dev gcc make gcc binutils build-essential wget pkg-config libseccomp-dev:$PKG_ARCH libasound2-dev:$PKG_ARCH libsystemd-dev:$PKG_ARCH libssl-dev:$PKG_ARCH zlib1g-dev:$PKG_ARCH libgpiod-dev:$PKG_ARCH libgpiod2:$PKG_ARCH libspeex-dev:$PKG_ARCH libspeexdsp-dev:$PKG_ARCH libsrtp2-dev:$PKG_ARCH libgsm1-dev:$PKG_ARCH libsnmp-dev:$PKG_ARCH libgstreamer1.0-dev:$PKG_ARCH libgstreamer-plugins-base1.0-dev:$PKG_ARCH libgstreamer-plugins-bad1.0-dev:$PKG_ARCH libwebsockets-dev:$PKG_ARCH libgstrtspserver-1.0-dev:$PKG_ARCH libgstreamermm-1.0-dev:$PKG_ARCH && apt-get clean && apt-get autoremove && rm -rf /var/lib/apt/lists/*
---> Running in 94f55da5c0dd
Get:1 http://snapshot.debian.org/archive/debian/20200908T070000Z bullseye InRelease [116 kB]
Get:2 http://snapshot.debian.org/archive/debian/20200908T070000Z bullseye-updates InRelease [38.8 kB]
Get:3 http://snapshot.debian.org/archive/debian-security/20200908T070000Z bullseye-security InRelease [44.1 kB]
Get:4 http://snapshot.debian.org/archive/debian/20200908T070000Z bullseye/main amd64 Packages [7683 kB]
Get:5 https://feeds.toradex.com/debian testing InRelease [14.9 kB]
Get:6 https://feeds.toradex.com/debian testing/non-free arm64 Packages [9481 B]
Get:7 https://feeds.toradex.com/debian testing/main arm64 Packages [111 kB]
Get:8 http://snapshot.debian.org/archive/debian/20200908T070000Z bullseye/main arm64 Packages [7572 kB]
Fetched 15.6 MB in 14s (1129 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
binutils is already the newest version (2.35-2).
binutils set to manually installed.
build-essential is already the newest version (12.8).
build-essential set to manually installed.
gcc is already the newest version (4:10.1.0-1).
gcc set to manually installed.
make is already the newest version (4.3-4).
make set to manually installed.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libopencv4.2-java : Depends: libopencv4.2-jni (>= 4.2.0+dfsg-6+toradex2) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
I’ve tried installing libopencv4.2-jni but still get the error. Is this a problem with debian-cross-toolchain-arm64:2-bullseye?
