Colibri iMX6DL 512MB IT
Colibri Evaluation Board
Running in WSL (Ubuntu 18.04.5 LTS
When I setup torizoncore-builder like so:
leighjboyd@EMERALENOVO1:/mnt/c/github3/EmeraBlockEnergyBox/deviceTreeOverlay/tcbworkdir$ cat ArmEmulation.sh
#! /bin/bash
wslfetch
sudo apt-get update && sudo apt-get install rsync ssh
docker --version
docker run hello-world
docker run --rm -it --privileged torizon/binfmt
docker run --platform linux/arm/v7 --rm -it arm32v7/debian arch
docker run --platform linux/arm64/v8 --rm -it arm64v8/debian arch
rm tcb-env-setup.sh*
wget https://raw.githubusercontent.com/toradex/tcb-env-setup/master/tcb-env-setup.sh
source ./tcb-env-setup.sh
with my .yaml file like so:
leighjboyd@EMERALENOVO1:/mnt/c/github3/EmeraBlockEnergyBox/deviceTreeOverlay/tcbworkdir$ cat tcbuild.yaml | grep -v "#"
input:
easy-installer:
local: torizon-core-docker-evaluation-colibri-imx6-Tezi_5.6.0-devel-202202+build.21.container.tar
customization:
filesystem:
- changes/
device-tree:
overlays:
add:
- my-colibri-overlay.dts
output:
easy-installer:
local: torizon-core-docker-evaluation-colibri-imx6-Tezi_5.6.0-devel-SPI-202203+build.21.container
I get:
leighjboyd@EMERALENOVO1:/mnt/c/github3/EmeraBlockEnergyBox/deviceTreeOverlay/tcbworkdir$ torizoncore-builder build
Building image as per configuration file 'tcbuild.yaml'...
=>> Handling input section
Unpacking Toradex Easy Installer image.
An unexpected Exception occured. Please provide the following stack trace to
the Toradex TorizonCore support team:
File "/builder/torizoncore-builder", line 215, in <module>
mainargs.func(mainargs)
File "/builder/tcbuilder/cli/build.py", line 424, in do_build
build(args.config_fname, args.storage_directory,
File "/builder/tcbuilder/cli/build.py", line 391, in build
handle_input_section(config["input"], storage_dir=storage_dir)
File "/builder/tcbuilder/cli/build.py", line 80, in handle_input_section
handle_easy_installer_input(props["easy-installer"], **kwargs)
File "/builder/tcbuilder/cli/build.py", line 101, in handle_easy_installer_input
images_cli.images_unpack(
File "/builder/tcbuilder/cli/images.py", line 393, in images_unpack
images.import_local_image(image_dir, dir_list[0], dir_list[1], dir_list[2])
File "/builder/tcbuilder/backend/images.py", line 295, in import_local_image
subprocess.check_output(tarcmd, shell=True, stderr=subprocess.STDOUT)
File "/usr/lib/python3.9/subprocess.py", line 424, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File "/usr/lib/python3.9/subprocess.py", line 528, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command 'cat /workdir/torizon-core-docker-evaluation-colibri-imx6-Tezi_5.6.0-devel-202202+build.21.container.tar | cat | tar -xf - -C /storage/tezi.tmp' returned non-zero exit status 2.
This was my overlay file, incase that was the culprit (most likely… but I could have sworn this worked earlier..)
/dts-v1/;
/plugin/;
/* Colibri SSP */
&ecspi4 {
mcp251x0: mcp251x@0 {
compatible = "microchip,mcp2515";
reg = <0>;
clocks = <&clk16m>;
interrupt-parent = <&gpio3>;
interrupts = <27 0x2>;
spi-max-frequency = <10000000>;
status = "disabled";
/* To keep the CAN controller enabled by default,
* disable conflicting spidev. This spidev device
* enables with the devicetree overlay.
spidev0: spidev@0 {
compatible = "toradex,evalspi";
reg = <0>;
spi-max-frequency = <23000000>;
