Hello everyone.
I am developing a PCB to use with a verdin AM62 as photovoltaic Datalogger and i probably will use Torizon Cloud to monitoring the status. I also want to use Torizon Cloud with the previous datalogger version, that was not developed with torizon cpus and had a 32bit arm.
When i tried to install torizon connector, i receive a message that says: “armhf is currently not supported. Get in touch with us at community.toradex.com for more information.”
There is a way to install the torizon connector or will it be developed also for armhf?
Hoping you can help me, thanks.
Currently, Torizon Connector does not support armhf (32-bit ARM) architecture. The error message you’re receiving indicates this limitation explicitly.
For your Verdin AM62-based datalogger, you’ll be able to use Torizon Cloud without issues, as the Verdin AM62 runs on ARM64 architecture, which is fully supported(1).
However, for your previous datalogger version running on 32-bit ARM, you have a few options:
Contact Toradex directly through the Community to inquire about armhf support plans and potential timelines for this architecture.
Consider migrating to ARM64 if your hardware permits, as this would give you full access to Torizon Cloud capabilities including device monitoring(2).
Evaluate alternative monitoring solutions for your legacy 32-bit ARM device while using Torizon Cloud for your new Verdin AM62-based hardware.
The documentation doesn’t indicate when or if armhf support will be added to Torizon Connector. I recommend reaching out through the community forum as suggested in the error message to get the most current information about roadmap plans for armhf architecture support.
Greetings @a.bresolin,
Currently we have no roadmap for arm32/armhf support for the Torizon Connector. I can make the request on your behalf to our product team though. If you would like me to.
Just to have more information on your environment. What kind of arm32 device is this? If you can share this information with us.
Also, what is your timeline for needing Torizon Connector support for arm32?
