Hi team,
I’m trying to use the RaspPi Sense hat, and since the module is not available in the feeds, I’m building it myself.
I could manage most of the dependencies (Pillow being the most troublesome) but when trying to run the program, I’m missing RTIMULib: RTIMULib/Linux/python at master · RPi-Distro/RTIMULib · GitHub.
So, I’m looking to also build it but I get an error with aarch64-linux-gnu-gcc.
Step 10/14 : RUN cd rtimulib/Linux/python && python3 setup.py build
---> Running in b110a9325bbc
running build
running build_ext
building 'RTIMU' extension
creating build
creating build/temp.linux-aarch64-3.7
creating RTIMULib
creating RTIMULib/IMUDrivers
aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DHAL_QUIET -I../../RTIMULib -I/usr/include/python3.7m -c PyRTIMU.cpp -o build/temp.linux-aarch64-3.7/PyRTIMU.o -std=c++0x
error: command 'aarch64-linux-gnu-gcc' failed with exit status 1
ERROR: Service 'rpi-hats-python' failed to build: The command '/bin/sh -c cd rtimulib/Linux/python && python3 setup.py build' returned a non-zero code: 1
What I’ve been reading mostly suggest to install python3-dev, which is already installed. I also tried to go through the cross-compiling route but it doesn’t seem to work either (it gets built in x86_64).
Am I missing something in the Dockerfile? Dockerfile:
ARG IMAGE_ARCH=arm64v8
# For Apalis iMX8 use IMAGE_ARCH=arm64v8
FROM torizon/$IMAGE_ARCH-debian-base:buster
RUN apt-get update \
&& apt-get install -y --no-install-recommends python3 \
python3-setuptools \
python3-influxdb \
wait-for-it \
python3-pip \
&& apt-get clean && apt-get autoremove && rm -rf /var/lib/apt/lists/*
RUN apt-get update && apt-get install -y procps
RUN apt-get update && apt-get install -y python3-dev
RUN python3 -m pip install --upgrade pip
RUN python3 -m pip install --upgrade Pillow
RUN pip3 install numpy
COPY RTIMULib rtimulib
COPY sense-hat sense-hat
RUN cd sense-hat && python3 setup.py install
COPY rpi-hats-python.py /usr/bin
ENTRYPOINT ["python3","/usr/bin/rpi-hats-python.py"]
#ENTRYPOINT ["wait-for-it", "influxdb:8086", "-t", "60", "--", "/bin/bash"]
Complete Docker build log:
alvaro@alvaro-toradex:~/Toradex/FATorizonDemo/RaspPiDemo/Source$ docker-compose up --build
Building rpi-hats-python
Step 1/14 : ARG IMAGE_ARCH=arm64v8
Step 2/14 : FROM torizon/$IMAGE_ARCH-debian-base:buster
# Executing 1 build trigger
---> Using cache
---> b2ce468568e7
Step 3/14 : RUN apt-get update && apt-get install -y --no-install-recommends python3 python3-setuptools python3-influxdb wait-for-it python3-pip && apt-get clean && apt-get autoremove && rm -rf /var/lib/apt/lists/*
---> Using cache
---> af6c4105a100
Step 4/14 : RUN apt-get update && apt-get install -y procps
---> Using cache
---> 2248cc66e341
Step 5/14 : RUN apt-get update && apt-get install -y python3-dev
---> Using cache
---> 5e4f0506391e
Step 6/14 : RUN python3 -m pip install --upgrade pip
---> Using cache
---> 7caede36f471
Step 7/14 : RUN python3 -m pip install --upgrade Pillow
---> Using cache
---> f4f321bcf3ed
Step 8/14 : RUN pip3 install numpy
---> Using cache
---> 93794d7f47cc
Step 9/14 : COPY RTIMULib rtimulib
---> Using cache
---> 9b51dfbc3ee4
---> Running in 6fd9c94d494e
running build
running build_ext
creating build
creating RTIMULib
Thanks, Alvaro.
