Torizon boot error when using multilib option in yocto
Spec:
Model: Apalis iMX8QM 4GB WB IT V1.1 E
Carrier board: Ixora V1.2A
OS: Linux 5.6.0
I’m trying to build a 64bit torizon-core-docker image with 32bit compat libraries.
I tried to build an image with yocto using multilib option added like below in local.conf file.
require conf/multilib.conf
MULTILIBS = "multilib:lib32"
DEFAULTTUNE_virtclass-multilib-lib32 = "armv7athf-neon"
IMAGE_INSTALL_append = "lib32-bash lib32-glibc lib32-libgcc lib32-libstdc++"
when booting, u-boot prompts the following error
## Error: "bootcmd_run" not defined
If I remove the multilib options, it boots fine.
I’m not very sure but it may seem to be related with this issue?
I would appreciate any hints or suggestions.
Thank you.
Greetings @jammingyu9,
May I ask why you are trying to re-build TorizonCore with 32bit compat libraries? Are you running some kind of legacy arm32 program? Also are you trying to run this on the base OS or inside a container?
As for your issue itself it’s strange. In our meta-layer we define bootcmd_run in this file that gets imported during boot time: meta-toradex-torizon/recipes-bsp/u-boot/u-boot-distro-boot/uEnv.txt.in at kirkstone-6.x.y · toradex/meta-toradex-torizon · GitHub
How your changes managed to “undefine” this, is not obvious. In the custom image you created can you locate this uEnv.txt file? Perhaps somehow it got altered or affected.
