I am using Toradex iMx8 GB and Mallow Carrier board.
Please guide how to set player which will help to encode the videos so that we will run on that board only and decode it before playing without hampering video quality and speed with audio.
Thank you for your question!
To set up both video encoding and decoding (playback) on your Toradex iMX8 board efficiently, you can use GStreamer, which utilizes the hardware’s VPU for fast, high-quality video processing. Below are simple steps to get you started:
1. Encoding a Video Using GStreamer
You can encode a video file with the following command. This example generates a test video, encodes it to H.264 using hardware acceleration, and saves it as MP4:
