the VS Code extension “Toradex Torizon Support” is very annoying during initialization if Docker is not running. There is a pop-up at the bottom right which cannot be closed and in the output window REST messages are spammed.
Will this be addressed in future releases? Maybe at least add a timeout. I would prefer not to enable/disable extensions all the time. This also popups when launching an empty VS Code.
Popup bottom right says:
Initializing Torizon Extension: is Docker running?
Output window messages:
INFO:root:REST -> /api/version/docker
INFO:root:REST <- /api/version/docker - 500
