Hi all,
Just a quick question, will the toradex OTA solution work with Android automotive?
Hi all,
Greetings @kalonmartin,
The short answer here is no.
The longer answer is that I don’t believe the technology stack that we currently use for our OTA solution is compatible with Android. For context the client we use on the device-side is called “OSTree”. As far as I can tell I can’t find any evidence of OSTree having been used on Android before.
As an alternative perhaps you can check out a solution from our partner “Kynetics” called Update-Factory: Over-The-Air Update Solutions | Toradex Developer Center
This solution should be more suited to android systems.
