I have an environment set up to build TorizonCore with yocto for Colibri iMX6ULL following the tutorial below:
I’m using the repo init command as below:
repo init -u https://git.toradex.com/toradex-manifest.git -b dunfell-5.x.y -m torizoncore/default.xml
Sometimes when I change something in my layer, eg my custom application, or even with no changes at all and rebuild the image with bitbake torizon-core-lite, the toradex linux gets downloaded and rebuilt again as well as kernel modules and etc.
For example:
Currently 1 running tasks (5807 of 5965) 97% |######################################################################################################################################################## |
0: linux-toradex-mainline-5.4.77+gitAUTOINC+3ade7cf22b_7aaf6c2823-r0 do_compile_kernelmodules - 2m42s (pid 473274)
I suspect that happens because when we source setup-environment, it in turn sources the setup-environment-internal which has the following inside:
# This is needed when building on integration. With use-head-next you
# always get the newest kernel. Without use-head-next your build may fail.
MACHINEOVERRIDES =. "use-head-next:"
Is that the expected behavior for dunfell-5.x.y and default.xml?
What should I do if I want to fix a specific linux version?
