I am using Linux BSP 2.8 on Colibri VF50. I am trying to update the openssl package for security reasons.
As I understand it, I have to patch the openssl package with patches from here:
http://cgit.openembedded.org/openembedded-core/log/meta/recipes-connectivity/openssl?h=master
Starting after patch “openssl: update 1.0.2n → 1.0.2o” and adding each patch, ending at “openssl: Upgrade 1.1.1c → 1.1.1d”
I have created an openssl folder in my layer and added an “openssl_1.0.2o.bbappend” file:
FILESEXTRAPATHS_prepend := "${THISDIR}/files:"
SRC_URI += " \
file://001-fix-upstream-version-check-for-1.0-version.patch \
I have then added the first patch “openssl: fix upstream version check for 1.0 version” by copying the text from here:
and pasting it to file “/mylayer/openssl/files/001-fix-upstream-version-check-for-1.0-version.patch”.
On compiling, I get the following error output:
ERROR: openssl-1.0.2o-r0 do_patch: Command Error: 'quilt --quiltrc /opt/TORADEX_COLIBRI_VF_V2.8/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/openssl/1.0.2o-r0/recipe-sysroot-native/etc/quiltrc push' exited with 0 Output:
Applying patch 001-fix-upstream-version-check-for-1.0-version.patch
can't find file to patch at input line 18
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|From 50dc3283e39e85912cdbeb9e885dcd22011d4a51 Mon Sep 17 00:00:00 2001
|From: Alexander Kanavin <alexander.kanavin@linux.intel.com>
|Date: Thu, 17 May 2018 14:38:35 +0300
|Subject: openssl: fix upstream version check for 1.0 version
|Signed-off-by: Alexander Kanavin <alexander.kanavin@linux.intel.com>
|Signed-off-by: Ross Burton <ross.burton@intel.com>
| meta/recipes-connectivity/openssl/openssl10.inc | 1 +
| 1 file changed, 1 insertion(+)
|(limited to 'meta/recipes-connectivity/openssl')
|diff --git a/meta/recipes-connectivity/openssl/openssl10.inc b/meta/recipes-connectivity/openssl/openssl10.inc
|index 645d64ec85..f7a8de823a 100644
|--- a/meta/recipes-connectivity/openssl/openssl10.inc
|+++ b/meta/recipes-connectivity/openssl/openssl10.inc
No file to patch. Skipping patch.
1 out of 1 hunk ignored
Patch 001-fix-upstream-version-check-for-1.0-version.patch does not apply (enforce with -f)
ERROR: openssl-1.0.2o-r0 do_patch: Function failed: patch_do_patch
ERROR: Logfile of failure stored in: /opt/TORADEX_COLIBRI_VF_V2.8/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/openssl/1.0.2o-r0/temp/log.do_patch.5173
ERROR: Task (/opt/TORADEX_COLIBRI_VF_V2.8/build/../layers/openembedded-core/meta/recipes-connectivity/openssl/openssl_1.0.2o.bb:do_patch) failed with exit code '1'
ERROR: openssl-native-1.0.2o-r0 do_patch: Command Error: 'quilt --quiltrc /opt/TORADEX_COLIBRI_VF_V2.8/build/tmp-glibc/work/x86_64-linux/openssl-native/1.0.2o-r0/recipe-sysroot-native/etc/quiltrc push' exited with 0 Output:
ERROR: openssl-native-1.0.2o-r0 do_patch: Function failed: patch_do_patch
ERROR: Logfile of failure stored in: /opt/TORADEX_COLIBRI_VF_V2.8/build/tmp-glibc/work/x86_64-linux/openssl-native/1.0.2o-r0/temp/log.do_patch.4060
ERROR: Task (virtual:native:/opt/TORADEX_COLIBRI_VF_V2.8/build/../layers/openembedded-core/meta/recipes-connectivity/openssl/openssl_1.0.2o.bb:do_patch) failed with exit code '1'
I am a Yocto/Openembedded newby and not sure what I am doing wrong. Any guidance will be appreciated.
