USB Device not found while connecting the development board to the host pc .
And i have connected to the usb type A port.
But while running the batch file i cant able execute it fully.
Same happens with my Iris board powered from lab power supply. Perhaps supply voltage rise time is too high, perhaps some noise, but if I instead reduce voltage with a knob, then turn it on, the rise voltage slowly with knob, then recovery USB device is recognised.
Could you provide the software and hardware versions of your setup?
Hope you are hardware connections are as per the Recovery article. Which windows are you using 7 or 10? and is there any USB hub in between PC and target? if any hub is connected, remove the same and try the recovery method with new Toradex easy installer
issue solved. The actual issue is with the module hardware reset not being done properly. I asked them to try the software reset(bmode usb) method and it worked.
