Hi TDX support,
My platform is Colibri iMX6ULL 512MB Wi-Fi / Bluetooth IT V1.1A on iris v1.1 carrier board. I’m using TEZI version: Colibri-iMX6ULL_ToradexEasyInstaller_1.8-20181019
My objective is to install a BSP package (uboot, kernel, filesys) using TEZI via a USB drive. Preferably I would like to do this using the auto-install feature, but when that did not work I tried using the GUI via VNC.
I have read and followed the TEZI guide here Downloads & Installers | Toradex Developer Center but I can’t get the installer to recognise any images I put onto the USB drive - it only shows images on the internet. USB drive is formatted FAT32 in ubuntu. I have tried pressing refresh before and after disabling RNDIS.
I have tried using my own bit-baked tezi package and the Toradex reference image downloaded from https://docs.toradex.com/106404-colibri-imx6ull-linux-console-image-tezi.tar
I unzip the contents of the folder inside the *.tezi.tar file to the root of the USB flash drive, i.e. the result is a flat file structure (without any directories):
$ ls /media/gareth/gg/
Console-Image-colibri-imx6ull.tar.xz
imx6ull-colibri-eval-v3.dtb
imx6ull-colibri-wifi-aster.dtb
imx6ull-colibri-wifi-iris-v2.dtb
wrapup.sh
image.json
imx6ull-colibri-iris.dtb
imx6ull-colibri-wifi-eval-v3.dtb
marketing.tar
u-boot-nand.imx
zImage
imx6ull-colibri-aster.dtb
imx6ull-colibri-iris-v2.dtb
imx6ull-colibri-wifi-iris.dtb
prepare.sh
uEnv.txt
On the console port of TEZI lsusb does not show the drive, nothing is mounted and no sda devices appear in /dev:
/ # lsusb
Bus 002 Device 001: ID 1d6b:0002
Bus 001 Device 001: ID 1d6b:0002
/ # mount
/dev/root on / type squashfs (ro,relatime)
devtmpfs on /dev type devtmpfs (rw,relatime,size=181652k,nr_inodes=45413,mode=755)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
configfs on /sys/kernel/config type configfs (rw,relatime)
devpts on /dev/pts type devpts (rw,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
tmpfs on /var/volatile type tmpfs (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
/ # ls /dev/sda*
ls: /dev/sda*: No such file or directory
dmesg looks like:
# dmesg | grep -i usb
[ 0.090254] mxs_phy 20c9000.usbphy: Looking up phy-3p0-supply from device tree
[ 0.091434] mxs_phy 20ca000.usbphy: Looking up phy-3p0-supply from device tree
[ 0.143092] VCC_USB[1-4]: 5000 mV
[ 0.143233] reg-fixed-voltage regulator-usbh-vbus: Looking up vin-supply from device tree
[ 0.143305] VCC_USB[1-4]: supplied by 5V
[ 0.143420] reg-fixed-voltage regulator-usbh-vbus: VCC_USB[1-4] supplying 5000000uV
[ 0.146444] usbcore: registered new interface driver usbfs
[ 0.146621] usbcore: registered new interface driver hub
[ 0.146894] usbcore: registered new device driver usb
[ 0.582043] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.582502] usbcore: registered new interface driver usb-storage
[ 0.582844] usbcore: registered new interface driver usbserial
[ 0.582951] usbcore: registered new interface driver usbserial_generic
[ 0.583055] usbserial: USB Serial support registered for generic
[ 0.583181] usbcore: registered new interface driver ftdi_sio
[ 0.583297] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 0.583424] usbcore: registered new interface driver pl2303
[ 0.583531] usbserial: USB Serial support registered for pl2303
[ 0.586351] usbmisc_imx 2184800.usbmisc: Looking up vbus-wakeup-supply from device tree
[ 0.586393] usbmisc_imx 2184800.usbmisc: Looking up vbus-wakeup-supply property in node /soc/aips-bus@02100000/usbmisc@02184800 failed
[ 0.586426] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 0.588287] imx_usb 2184000.usb: Can't register ci_hdrc platform device, err=-517
[ 0.596562] imx_usb 2184200.usb: Looking up vbus-supply from device tree
[ 0.600542] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 0.615032] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 0.617126] hub 1-0:1.0: USB hub found
[ 0.692811] usbcore: registered new interface driver usbhid
[ 0.692830] usbhid: USB HID core driver
[ 0.735222] imx_usb 2184000.usb: Looking up vbus-supply from device tree
[ 0.740683] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 0.755025] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 0.757191] hub 2-0:1.0: USB hub found
[ 2.371189] usb0: HOST MAC 00:14:2d:ff:ff:fe
[ 2.372192] usb0: MAC 00:14:2d:ff:ff:ff
[ 2.372699] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
