I have experienced an issue when using Easy Installer on i.MX7D module, running on Aster carrier board. The display is working as expected, but the vertical axis of the touchscreen is flipped, i.e. if there is a press on the top, Colibri registers the touch on the bottom etc. Such things do not happen on the horizontal axis. Is there anything to fix his problem, since Easy Installer has no pre-built calibration?
Dominykas
