Hi
Do you have more information about how to use mkfs_option parameter in the image.json configuration file (Toradex Easy Installer Configuration Files | Toradex Developer Center)?
Actual I have the following open questions:
- is “mkfs_options”: “-L var” same as using “label”: “var”?
- can we use “mkfs_options”: “-U 203bd64b-d627-4e82-99fd-8e761785a1b4” to define the UUID for the partition?
Many thanks for your feedback!
Andreas
Hi @AndreasM,
I quickly checked the code and here are the answers:
is “mkfs_options”: “-L var” same as using “label”: “var” ?
The label option applies the correct label option to mkfs according to the filesystem being created. From what I saw it applies -L for ext2, ext3, ext4 and ntfs.
The mkfs_options just copies all the given arguments and pastes them before the device name while creating the mkfs command line.
It should be possible to do that, see previous answer.
Rafael Beims
