I am installing WEC7 on Apalis iMX6Q by referring to this.
However, executing “recovery-windows.bat” will also result in an error.
“g_dnl_register: failed!, error: -19” link text
Commercial temperature grade DDR3 timings.
Trying to boot from MMC1
U-Boot 2016.11-1.1.0+g51b53b4 (Sep 06 2017 - 15:19:08 -0700)
CPU: Freescale i.MX6Q rev1.5 at 792 MHz
Reset cause: POR
I2C: ready
DRAM: 1 GiB
PMIC: device id: 0x10, revision id: 0x21, programmed
Using default environment
In: serial_mxc
Out: serial_mxc
Err: serial_mxc
Model: Toradex Apalis iMX6 Quad 1GB V1.1B, Serial# 05186469
Net: using PHY at 7
FEC [PRIME]
Apalis iMX6 # bmode usb
resetting ...
Trying to boot from USB SDP
SDP: initialize...
SDP: handle requests...
The error is the same whether you use the “bmode usb” command or short the pad.
I changed the USB cable and changed the carrier board to another Ixora, referring to other postings, but the result was the same.
What else should I try?
