Toradex_CE7_sdk.msi
im using visual studio 2008 with Toreadex CE7_sdk..but at the run time it shows
ATL error.
IstrlenW: is not a member of 'ATL'.
hi,
did you install all the updates referenced here?
All version are match which is mention in document
Dear @programmer
Can you reduce your project to a small test application which will run on our standard boards, and still shows the error?
This would allow us to look at your project settings and hopefully find the problem.
Regards, Andy
