Toradex_CE7_SDK_2_1 sdk not shown in vs2008
We have Installed the Toradex_CE7_SDK_2_1 SDK for WEC7 .
But when we try to create new qt project we are not able to see the sdk for WEC7,instead only prior installed
Toradex_CE600(ARMv4I)/QT 4.4.4 is shown.
How to solve this.
Also if we install Toradex_CE6_SDK_2_1 sdk will there be any issue for old projects which are created with Toradex_CE6_SDK_2_0 sdk
Dear @zecons,
I am trying to reproduce it, please wait for a day, get back you soon.
Can i know the reply for this question
Dear @zecons,
The SDK name remains same on those two versions. Hence it won’t affect the old projects. SDK names and few import settings are important for the application project settings that is the same on those two releases.
Dear @zecons,
There are already example projects with Toradex_CE700 SDK configured. Could you please check those projects can you able to build? If you are able to build then you would make similar new vcproj manually and develop the project.
