I am just testing CAN bus behaviour for WEC7/Apalis,OS image is based on 1.5b4
I am using Toradex CE library 2.3. I test with an IO board that is connected via CAN-bus. On this IO board I have made a loop back from an output to an input. Quite seldom (maybe 1 in 100000) I do not get back the answer.
In release notes for reivision 2.4 (which obviously has not been released yet) under number 45299 you say that it is a known bug for Colibri modules that sometimes CAN messages are lost
Is this a known bug for Colibri only or also for Apalis ?
Is this bug also in revision 2.3 ?
I have also tested 2.3b4567, After a few seconds the whole system was blocked (I could not even access the system via telnet). We have 2 threads, one for sending and one for receiving. As I saw under number 41015 you made modifications in 2.3 regarding this scenario.
Kind regards
Dear @Frax222
The issue about occasional loss of CAN messages (#45299) affects both Colibri and Apalis iMX6 modules. It was solved in the preliminary version of the libraries V2.3b4536.
- The build number is increasing only, so the problem should also be solved in the version V2.3b4567 that you mentioned in your question.
- V2.3 is older than any V2.3bxxxx preliminary version (sorry for the confusion), so V2.3 has this known bug.
Issue #41015 was only about the blocking of Can_Read()
vs Can_Write()
, which should never affect the whole system.
All in all it seems you triggered an unknown problem in the libraries. I would appreciate the source code of a test application which allows us to reproduce and debug the issue - ideally by connecting two Colibri / Apalis boards, so we don’t have a dependency on unknown external IO-boards.
Regards, Andy
hello,
thank you for clarification. I will try to provide a test application - but this will take some time.
Kind regards
please find attached a test application that shows the problem.
This test application is based on an earlier test application for hardware acceleration of bitblt (full hd - this now works when ipumem is increased).
You have to start blttest.exe on two systems. Default ID for CAN telegrams is 0x180 = 384. On the second system you have to enter the ID as command line argument, e.g. blttest.exe 385
There are 3 threads:
Thread10ms which should run every 10ms, priority is 50. This thread puts each time it runs 5 telegrams into a buffer
ThreadCanSend, priority 52, checks the buffer and sends the data
ThreadCanRead, priority 49, it reads incomming telegrams and checks whether one telegram is missing
With Toradex Libraray 2.3 I see that there are missed telegrams (not receiving subsequent numbers).
Also with 2.3b4536 I can see missed telegrams, but the systems do not block.
With 2.3b4567 the systems get blocked as soon as I connect CAN bus between the two systems.
There is a function DrawTextBig in test application. The strange thing with this function is that depending on scaling factors the 10ms-Thread is sometimes not run every 10ms (but only after 12ms). Maybe this does also prevent CAN bus receive procedure from reacting in time.
I hope you can see the problems and find a solution.
Kind regards
Dear @Frax222
I am able to reproduce the issue here. It looks it will take some time to come up with a solution. Do you have any deadline until when you need this fixed?
Regards, Andy
Hello Andy,
do you think end of august would be possible ?
Kind regards
Dear @Frax222
From what we can judge now, we should be fine to have a solution by then.
Regards, Andy
Dear @Frax222,
Thank you for your patience. We solved the bug and would like to share the preliminary release with you for your testing, please download it from here : CAN Bug Fix.
Please let us know is that solves the issue.
I have now tested CE library of 12.09.2019 in our application. It works without problems.
Thank you for your assistance !
Kind regards
