I am using TM035KBH02 Resistive touch pad and now i am trying to interface with Colibri_T30.So i need the procedure for connection and drivers installation on host computer(using Linux-14.04LTS,32bit).
hi @som
Could you provide the software version of your module?
How did you connect the resisitive touch pad to the module?
Could you provide some information about the touch interface (Company Name, Model, …)?
Looks like a regular parallel RGB display with a resistive touch panel which should just work given you are using the right adapter/cable and proper display timings for it. No special drivers are required.
hi jaski.tx ,
I am using Colibri_t30 V1.1A software version and still i am not interfacing resistive touchpad display with target module.I have attached the PDF below.link text
Company Name:-Tianma
If you are interfacing with the target module. What exactly are you doing then?
