I have written a complex application in Python to control peripherals over LAN with GUI in Tkinter module. I have been struggling for a few days now with exporting the application using your extension for VS code. Everything looks good except just Tkinter which takes care of the GUI. I’ve tried everything, but I always end up with the message: _tkinter.TclError: couldn’t connect to display “:0” or couldn’t open. I also tried your sample here: GitHub - leonheldattoradex/pysimplegui
but without success (I don’t know how to apply it). I read somewhere that Torizon OS does not support Xserver, which tkinter needs. Is that true? Is it possible to respect graphical applications in tkinter on Torizon?
it is a combination of MB Apalis iMX8, carrier board Ixora.
Thank you in advance
The error _tkinter.TclError: couldn’t connect to display “:0” or literally means it tried to find a display (set by the WAYLAND_DISPLAY or DISPLAY variables, run printenv inside your container application to make sure those are set) but it wasn’t able to.
It either means that:
you’re not running a display server: make sure that you’re running a Weston container (pysimplegui/docker-compose.yaml at main · leonheldattoradex/pysimplegui · GitHub).
or you’re not properly connecting the display server to your application: make sure you’re sharing the
tmpfolder that contains the Wayland socket (pysimplegui/docker-compose.yaml at main · leonheldattoradex/pysimplegui · GitHub, pysimplegui/docker-compose.yaml at main · leonheldattoradex/pysimplegui · GitHub) before running your Tkinter container.
Please check this thread, there’s a lot of information there about this specific error message: Containers not running in TorizonCore with evaluation containers for iMX8M-Plus - #22 by SCordibella
I also tried your sample here … I don’t know how to apply it
You need to copy it over to Torizon OS and run it with docker-compose up.
It does through XWayland (a Xserver under Wayland), so it shouldn’t have problems there.
