I am using the Apalis TK1 module and would like to use a hardware image encoder to produce MJPEG images.
For the Apalis IMX6 module I used the i.MX VPU API Library. Is there anything similar for the TK1?
What is the simplest method to use hardware to compress a image buffer using the TK1?
Thank you,
Shaun
