I’m running a TK1 with Ubuntu and NVIDIA JetPack.
Initially, the Android USB gadget is not configured. Ideally, I want it to be configured by default as an rndis device however I am unsure of how to do this. I can see how this is done in Angstrom but the procedure does not appear to be the same for Ubuntu.
Also, I would like the IP address of the rndis device to be set similar to our Angstrom configuration which uses the following configuration in the rndis.network file:
[Match]
Type=gadget
[Network]
Address=192.168.11.1/24
DHCPServer=yes
Currently, it obtains an auto IPv4 address of 169.254.44.156.
It would appear that Ubuntu doesn’t ever look for the rndis.network file - either that or it needs to be told to look for it, which i’m unsure of.
