TK1 internal RTC power consumption
In the apalis TK1 module datasheet states "The RTC on the module is not designed for ultra-low power consumption (typical current consumption can be found in section 9.3). "
In section 9.3 the numbers still TBD.
Is there an estimated date for when these numbers would be avilable. We would need them to design in an appropriate RTC battery.
Our validation of the V1.1A modules have shown a typical current consumption of 8.9μA at the battery input rail if all other supply rails are removed from the module.
