Having successfully managed to get Qt 5.10 up and running on Ubuntu on the TK1 (using JetPack rootfs), I’m now trying to get it up and running on a Angstrom image using LXDE 2.8.3 rootfs.
I’ve cloned the Qt 5.11.1 git repository and I’ve installed a number of packages (gcc, g++, xcblibs, etc) onto the TK1 target before rsync
ing the changes from /usr/lib
and /usr/include
back up to the host machines /usr/lib
and /usr/include
directories.
I then attempt to configure
Qt as follows:
cd qtbase
./configure -device linux-jetson-tk1-g++ -device-option CROSS_COMPILE=/home/me/gcc-linaro/bin/arm-linux-gnueabihf- -sysroot /home/me/Apalis-TK1_LXDE-Image_2.8.3/rootfs -nomake examples -nomake tests -prefix /usr/local/qt5 -extprefix $HOME/qt5 -hostprefix $HOME/qt5-host -opengl es2 -v
At the end of the configuration process, the following error is presented:
ERROR: The OpenGL functionality tests failed!
When I check back up the build options list, all of the entries underneath OpenGL are set to no
and now I’m a little bit lost as to where to head now.
This question may be better suited to the Qt community forum so i apologise in advance however given that it is Toradex hardware, I wondered whether there is something simple which I am missing or whether there is a more fundamental issue which may prevent Qt being cross-compiled and installed like this.
