Hello!
To measure the time difference between your Toradex system and a Windows system using the w32tm command, you can follow these steps:
Verify NTP Service on Toradex: Ensure that the NTP (Network Time Protocol) service is installed and running on your Toradex device. This is essential for the
w32tmcommand to work properly. -
Configure Firewall for Port 123: You need to allow traffic on UDP port 123 on your Toradex system. This involves:
- Accessing the firewall settings on your Toradex device.
- Creating a rule to permit NTP traffic on UDP port 123.
- Ensuring the NTP service is active and ready to respond to time queries from the Windows system.
Execute the w32tm Command: On your Windows system, use the following command to query the time difference:
w32tm /stripchart /computer:<Toradex_IP> /samples:5 /dataonlyReplace
<Toradex_IP>with the IP address of your Toradex system. This command will send NTP requests to the Toradex system and display the time difference in milliseconds. -
Troubleshooting Tips: If you encounter issues, check that:
- The Toradex system is reachable from the Windows system.
- The NTP service is correctly configured to respond on port 123.
- Both systems are synchronized to the same time source for accurate millisecond-level comparison.
By following these steps, you should be able to successfully measure the time difference between your Toradex and Windows systems.
