I need to install a Third-Party Firewall on win ce because my device don’t have a default firewall.
The reason for this requirement is that I need to disable NetBIOS because it collapse my LAN.
Thank you!!
Thank you!!
Dear @msolijen
What kind of problem are you facing when you try to do this?
Regards, Andy
Hi Andy,
The problem is that the device collapse my Lan with NBNS requests.
I dont know why
Thank you
Dear @msolijen,
Option #1:
If you want to remove NetBIOS component permanently on the device, you need to build a custom image with removing “SYSGEN_SMB_FILE and SYSGEN_SMB_UI” components, please use Vybrid winCE BSP and workspace to do that.
Option #2:
Please refer MSDN Windows Embedded Compact Platform forum for more information related NetBIOS discussion.
This https://social.msdn.microsoft.com/Forums/en-US/e14eae20-26ca-431d-b1cc-b166b7208b00/security-on-ethernet-for-win-ce-60?forum=winembplatdev would be more relevant to your topic.
Option #3:
Please try this quick approach, I didn’t test this. Please remove following registry using regedit (Start → Programs → ColibriTools–>RegEdit) tool and verify your issue is solved and let us know your feedback.
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\Netbios]
"DLL"="netbios.dll"
"Prefix"="NBT"
"Keep"=dword:1
"Order"=dword:11
[HKEY_LOCAL_MACHINE\Services\SMBServer]
"DLL"="smbserver.dll"
"Keep"=dword:1
"Order"=dword:12
"Prefix"="SMB"
"Index"=dword:0
