I am currently involved in the migration process from BSP 5.x to BSP 6.5. I am utilizing the VerdIn8mm on a customized board. However, I am encountering difficulties in loading the display driver with BSP 6, as I am receiving error messages.
Transitioning from BSP 5.x to BSP 6.5 involves several changes that could affect the functionality of your MIPI DSI panel, especially due to updates in the device tree structure, driver compatibility, and possibly the handling of peripherals like MIPI DSI. Given the information you’ve provided, here are a few steps and considerations to troubleshoot and potentially resolve the issue:
Device Tree Compatibility: Ensure that the device tree syntax and nodes are compatible with BSP 6.5. The Linux kernel version underlying BSP 6.5 might have introduced changes in how certain hardware components are initialized and managed. Pay special attention to the compatibility strings and property names.
Driver Support: Verify that the driver for your “geli,gl101b331m” panel is present and compatible with the Linux kernel version used in BSP 6.5. It’s possible that the driver needs updates or patches to work with the new BSP.
Backlight Configuration: The backlight configuration in your device tree snippet seems correct, but ensure that the PWM controller (&pwm1) and the GPIO (&gpio3) referenced are correctly defined elsewhere in your device tree with the correct properties for BSP 6.5.
Pinctrl Settings: Check the pin control settings (pinctrl-0 = <&pinctrl_gpio1> and pinctrl-0 = <&pinctrl_gpio_10_dsi>) to ensure they are correctly defined for BSP 6.5. The pin control configuration might have changed with the BSP update.
Error Messages: Analyze the error messages you’re receiving in detail. They can provide specific clues on what might be going wrong. Common issues could relate to missing nodes, incorrect property values, or driver incompatibilities.
Kernel Logs: Review the kernel boot logs for any messages related to the MIPI DSI interface, the panel driver, or the backlight. These logs can often point you directly to the source of the problem.
Documentation and Changes: Review the release notes and documentation for BSP 6.5, focusing on any noted changes in the display subsystem, MIPI DSI support, or device tree structures. There might be important migration notes relevant to your situation.
Test with a Reference Device Tree: If possible, test your setup with a reference device tree provided by Toradex for BSP 6.5 that includes support for a MIPI DSI display
