We are using Colibri vf61 with Linux 2.6
We are trying to drive a densitron display
Display doesnot has Hsync and VSync It has only DE(Data Enable)
How to adjust timing tn panel-simple. c to facilitate the same
Regards
hi aneesh
Could you give some more information about your hardware and software:
Which Hardware version of VF61 are you using? Which carrier board are you using?
Which bsp version? You can fill this in Environment.
Additionally:
Which densitron display exactly do you want to connect? Which connector will u use?
Thanks and best regards
Hardware Version 1.2A
Custom Carrier board developed internally
Version Linux Version 2.6
Attached Datasheet of Display
link text
40 pin frc connector is used
Hi aneesh,
please fill the hardware details in Hardware Environment of question. Which connector are you using to connect to your display?
HI aneesh
Check this site for adjust timings for you application. The sum of hactive = , hback-porch = and hsync-len = , should be 1056 in your case. The sum of vactive = , vback-porch = and vsync-len = , should be 45.
Further you can refer to this picture.
- Data sheet specifies only DataEnable Timings Only. Since it doesnt support HSync and VSync
- What configurations should be changed in toradex , so that we can Switch from Sync(Hs,VS) to DataEnable(DE) Mode
DataEnable signal is defined by Front-, back porch and hsync and vsync. The signals for hsync and vsync will be available at the output of module, but you don’t have to use them. Check the timing diagram on page 15. DataEnable is on when hsync or vsync are active.
this settings defines, if the signal is low (0) or high (1) active. This you have to try with the given module.
de-active = <1>;
hsync-active = <0>;
vsync-active = <0>;
pixelclk-active = <0>;
1 . We are using Colibri VF61
- we have following structure in vf-colibri eval-v3.dtsi
panel: panel {
compatible = “shanghai,tm070rbh10”;
//compatible = “shelly,sca07010-bfn-lnn”;
//backlight = <&bl>; // Removed Back Light to Free PWM - Aneesh K N
power-supply = <®_3v3>;
Should we use below format?
display: display@0 {
bits-per-pixel = <16>;
display-timings {
native-mode = <timing_vga>;
/* Standard VGA timing */
timing_vga: 640x480 {
clock-frequency = <25175000>;
hactive = <640>;
vactive = <480>;
hback-porch = <40>;
hfront-porch = <24>;
vback-porch = <32>;
vfront-porch = <11>;
hsync-len = <96>;
vsync-len = <2>;
hsync-active = <0>;
vsync-active = <0>;
yeah, you just have to adapt the number according to the datasheet of your display.
Do we have to change any uboot settings
We are receiving following error when executing make statement
~/linux-toradex$ make vf610-colibri-eval-v3.dtb
DTC arch/arm/boot/dts/vf610-colibri-eval-v3.dtb
Error: arch/arm/boot/dts/vf-colibri-eval-v3.dtsi:227.14-23 syntax error
FATAL ERROR: Unable to parse input tree
make[1]: *** [arch/arm/boot/dts/vf610-colibri-eval-v3.dtb] Error 1
make: *** [vf610-colibri-eval-v3.dtb] Error 2
which branch did you use to compile? Can you send a git diff log?
We Did Following Steps
- Cnaged added Densitron Structure to panel-simple.c (Attached File)
- Made Panel as Densitron in vf-colibri-eval-v3.dtsi (Attached File)
- We Updated zImage and Device Tree as mentioned in link Build U-Boot and Linux Kernel from Source Code | Toradex Developer Center
But the Screen we got is getting shifted unevenly(Attached File)
hi aneesh
I cannot open your jpeg images, how did you create them?
can you send the dmesg log in a file?
type fbset
in the console and send the output please?
mode “800x480”
geometry 800 480 800 480 24
timings 0 0 0 0 0 0 0
accel true
rgba 8/16,8/8,8/0,0/0
endmode
you should use either device tree changes or changes in panel-simple.c
For the panel-simple.c changes you should add the DE flags in configuration too.
static const struct drm_display_mode tpk_f07a_0102_mode = {
.clock = 33260,
.hdisplay = 800,
.hsync_start = 800 + 40,
.hsync_end = 800 + 40 + 128,
.htotal = 800 + 40 + 128 + 88,
.vdisplay = 480,
.vsync_start = 480 + 10,
.vsync_end = 480 + 10 + 2,
.vtotal = 480 + 10 + 2 + 33,
.vrefresh = 60,
.flags = DISPLAY_FLAGS_DE_HIGH,
I am also facing this issue with imx6. I have looked in imx6ull-colibri-eval-v3.dtsi. Kindly help where to change for 7" resistive touch lcd. I think to EDT ET070080DH6 data. and how enable DE mode from dtsi file. LCD timing details attached link text
,Hi i am also facing same issue with imx6. i have looked imx6ull-colibri-eval-v3.dtsi file, but and where i have to change. kindly support.
