TEZI has tezictl command.
This is useful in environments without LCDs.
There is no published documentation for this command, is it okay to use it?
Best regards.
Best regards.
Hi @developer0916,
tezictl
is treated as an internal tool only provided as-is without any warranty expressed or implied. It is usually used by us for debugging or internal proposes. Be aware that this is something we don’t intend to support for our customers.
Instead, I would recommend using Tezi with VNC. Our latest Tezi release supports VNC, you can download it with this link: Loading Toradex Easy Installer | Toradex Developer Center
Then, when you load Tezi, you can connect with your Host PC using a VNC viewer (like Remmina, for Linux UIbuntu). With that, you will have access to see Tezi and use your keyboard and mouse without display. The IP to connect is 192.168.11.1. Check this guide for more information: Downloads & Installers | Toradex Developer Center
Hiago.
Understood. Thanks for the response.
Best regards.
