U-Boot 2016.11-1.8.0+g07edca0bb8 (Oct 19 2018 - 13:33:39 +0000)
CPU: Freescale i.MX7D rev1.3 996 MHz (running at 792 MHz)
CPU: Extended Commercial temperature grade (-20C to 105C) at 38C
Reset cause: POR
DRAM: 512 MiB
PMIC: RN5T567 LSIVER=0x01 OTPVER=0x0d
NAND: 512 MiB
MMC: FSL_SDHC: 0
Using default environment
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX7 Dual 512MB V1.1D, Serial# 06404766
Net: FEC0
MMC: no card present
Booting Toradex Easy Installer…
ubi0: default fastmap pool size: 200
ubi0: default fastmap WL pool size: 100
ubi0: attaching mtd1
ubi0: scanning is finished
ubi0: attached mtd1 (name “mtd=4”, size 508 MiB)
ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
ubi0: good PEBs: 4059, bad PEBs: 5, corrupted PEBs: 0
ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 1303211635
ubi0: available PEBs: 0, total reserved PEBs: 4059, PEBs reserved for bad PEB handling: 75
No size specified → Using max size (21374744)
Read 21374744 bytes from volume rootfs to 82100000
Loading kernel from FIT Image at 82100000 …
Using ‘config@imx7d’ configuration
Trying ‘kernel@1’ kernel subimage
Description: Linux Kernel 4.1
Type: Kernel Image
Compression: uncompressed
Data Start: 0x821000dc
Data Size: 5308472 Bytes = 5.1 MiB
Architecture: ARM
OS: Linux
Load Address: 0x81000000
Entry Point: 0x81000000
Hash algo: md5
Hash value: 910fc4bfe6325ca943e1af0824a15957
Verifying Hash Integrity … md5+ OK
Loading ramdisk from FIT Image at 82100000 …
Trying ‘ramdisk@1’ ramdisk subimage
Description: SquashFS RAMdisk
Type: RAMDisk Image
Data Start: 0x826101fc
Data Size: 15929344 Bytes = 15.2 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: md5
Hash value: bf0a406d6fa572c48f601023ca980bd2
Loading fdt from FIT Image at 82100000 …
Trying ‘fdt@imx7d’ fdt subimage
Description: Colibri iMX7 Dual Device Tree
Type: Flat Device Tree
Data Start: 0x8354bf8c
Data Size: 45356 Bytes = 44.3 KiB
Architecture: ARM
Hash algo: md5
Hash value: 76f76a539fc485372532ae7cbf683d5b
Booting using the fdt blob at 0x8354bf8c
Loading Kernel Image … OK
Loading Device Tree to 8fff1000, end 8ffff12b … OK
Updating MTD partitions…
Starting kernel …
[ 0.347878] gpmi-nand 33002000.gpmi-nand: mode:5 ,failed in set feature.
[ 0.371063] imx_usb 30b10000.usb: Can’t register ci_hdrc platform device, err=-517
Running /etc/rc.local…
Colibri-iMX7_ToradexEasyInstaller_1.8-20181019
Welcome to Toradex Easy Installer
This is a Linux based installer for Toradex modules. Currently the
installer does not have a serial console interface. You can use the
Toradex Easy Installer through any of the available display interfaces
using USB mouse/keyboard or via network using VNC. Use:
ip addr show eth0
to display the Ethernet IP address or use USB RNDIS at IP 192.168.11.1.
USB PEN DRIVE IS CONNECTED BUT THE TEZI DOES NOT RECOGNIZE THE IMAGE IN USB
on VGA display it shows
Waiting fro external media or network
