I downloaded Tezi 7.3 from the following source today: Download Toradex Easy Installer | Toradex Developer Center
I started the Tezi on my computer with the following command: ./recovery-linux.sh
I got the following error (I interrupted the boot process to enable xtrace outputs):
U-Boot 2024.04-7.3.0+git.4db7ef83ebd6 (Jun 03 2025 - 06:47:58 +0000)
CPU: NXP i.MX8QM RevB A53 at 1200 MHz at 37C
DRAM: 2 GiB
Core: 203 devices, 24 uclasses, devicetree: separate
Loading Environment from nowhere... OK
In: serial
Out: serial
Err: serial
Model: Toradex 0048 Apalis iMX8QP 2GB WB V1.0B
Serial#: 06597545
Boot: USB
Reset cause: Software reset
BuildInfo:
- SCFW 83624b99, SECO-FW c9de51c0, IMX-MKIMAGE 71b8c18a, ATF 1b27ee3
- U-Boot 2024.04-7.3.0+git.4db7ef83ebd6
Detect USB boot. Will enter fastboot mode!
Net: eth0: ethernet@5b040000
Fastboot: Normal
Boot from USB for uuu
Apalis iMX8 # <INTERRUPT>
Apalis iMX8 #
Apalis iMX8 #
Apalis iMX8 #
Apalis iMX8 #
Apalis iMX8 #
Apalis iMX8 #
Apalis iMX8 # setenv xtrace yes
Apalis iMX8 # boot
+ boot
+ fastboot 0
Failed to configure default pinctrl
+ setenv fastboot_buffer 0x82e00000
Starting download of 1834 bytes
downloading of 1834 bytes finished
+ setenv fastboot_buffer 0x82e10000
Starting download of 117 bytes
downloading of 117 bytes finished
+ setenv fastboot_buffer 0x8a000000
Starting download of 42958743 bytes
downloading of 42958743 bytes finished
+ source 0x82e00000
## Executing script at 82e00000
+ env set fitconf_fdt_overlays
+ env set prefix
+ test -n
+ env set overlays_file overlays.txt
+ env set load_cmd load :
+ env set fitimage_addr 0x8a000000
+ env set overlays_addr 0x82e10000
+ env set bootcmd_args env set bootargs quiet video=LVDS-1:d video=HDMI-A-1:640x480-16@60D initcall_blacklist=vpu_driver_init rootfstype=squashfs root=/dev/ram autoinstall ${teziargs}
+ env set bootcmd_run echo "Bootargs: ${bootargs}" && bootm ${fitimage_addr}#conf-freescale_${fdtfile}${fitconf_fdt_overlays}
+ env set tezi_image tezi.itb
+ env set set_default_overlays env set fdt_overlays " apalis-imx8_hdmi_overlay.dtbo apalis-imx8_spi1_spidev_overlay.dtbo apalis-imx8_spi2_spidev_overlay.dtbo "
+ test x1 = x1
+ env set bootcmd_tezi ;
+ env set load_overlays_file env import -t ${overlays_addr} 0x200; test -n ${fdt_overlays} || run set_default_overlays
+ env set set_apply_overlays env set apply_overlays "for overlay_file in "\${fdt_overlays}"; do env set fitconf_fdt_overlays "\"\${fitconf_fdt_overlays}#conf-\${overlay_file}\""; env set overlay_file; done; true"
+ run load_overlays_file
+ env import -t 0x82e10000 0x200
+ test -n apalis-imx8_hdmi_overlay.dtbo apalis-imx8_spi1_spidev_overlay.dtbo apalis-imx8_spi2_spidev_overlay.dtbo
+ run set_apply_overlays
+ env set apply_overlays for overlay_file in ${fdt_overlays}; do env set fitconf_fdt_overlays "${fitconf_fdt_overlays}#conf-${overlay_file}"; env set overlay_file; done; true
+ run apply_overlays
+ env set fitconf_fdt_overlays #conf-apalis-imx8_hdmi_overlay.dtbo
+ env set overlay_file
+ env set fitconf_fdt_overlays #conf-apalis-imx8_hdmi_overlay.dtbo#conf-apalis-imx8_spi1_spidev_overlay.dtbo
+ env set fitconf_fdt_overlays #conf-apalis-imx8_hdmi_overlay.dtbo#conf-apalis-imx8_spi1_spidev_overlay.dtbo#conf-apalis-imx8_spi2_spidev_overlay.dtbo
+ true
+ run bootcmd_args
+ env set bootargs quiet video=LVDS-1:d video=HDMI-A-1:640x480-16@60D initcall_blacklist=vpu_driver_init rootfstype=squashfs root=/dev/ram autoinstall
+ run bootcmd_tezi
+ run bootcmd_run
+ echo Bootargs: quiet video=LVDS-1:d video=HDMI-A-1:640x480-16@60D initcall_blacklist=vpu_driver_init rootfstype=squashfs root=/dev/ram autoinstall
+ bootm 0x8a000000#conf-freescale_imx8qp-apalis-eval.dtb#conf-apalis-imx8_hdmi_overlay.dtbo#conf-apalis-imx8_spi1_spidev_overlay.dtbo#conf-apalis-imx8_spi2_spidev_overlay.dtbo
## Loading kernel from FIT Image at 8a000000 ...
Could not find configuration node
ERROR -2: can't get kernel image!
Apart from that, my device boots from BSP 7.2 perfectly (with patch from Missing support for Apalis IMX8QP 1.0 Boards in BSP 7 - #9 by allan.tx).
U-Boot 2024.04-7.2.0-devel+git.5c6f89c91d3d (Mar 14 2025 - 21:21:12 +0000)
DRAM: 2 GiB
In: serial
Out: serial
Err: serial
Serial#: 06597545
Boot: MMC0
Reset cause: POR
BuildInfo:
- SCFW 83624b99, SECO-FW c9de51c0, IMX-MKIMAGE 4622115c, ATF
- U-Boot 2024.04-7.2.0-devel+git.5c6f89c91d3d
flash target is MMC:0
Fastboot: Normal
Normal Boot
MMC: no card present
switch to partitions #0, OK
Scanning mmc 0:1...
Found U-Boot script /boot.scr
5974 bytes read in 2 ms (2.8 MiB/s)
## Executing script at 9d480000
Loading DeviceTree: imx8qp-apalis-v1.1-eval.dtb
176610 bytes read in 5 ms (33.7 MiB/s)
147 bytes read in 1 ms (143.6 KiB/s)
Working FDT set to 9d400000
Applying Overlay: apalis-imx8_hdmi_overlay.dtbo
2205 bytes read in 2 ms (1.1 MiB/s)
Applying Overlay: apalis-imx8_spi1_spidev_overlay.dtbo
551 bytes read in 2 ms (268.6 KiB/s)
Applying Overlay: apalis-imx8_spi2_spidev_overlay.dtbo
Applying Overlay: apalis-imx8_lvds_overlay.dtbo
2031 bytes read in 2 ms (991.2 KiB/s)
8233798 bytes read in 185 ms (42.4 MiB/s)
Bootargs: root=PARTUUID=8dfbeff1-02 ro rootwait console=tty1 console=ttyLP1,115200
Uncompressing Kernel Image to 0
## Flattened Device Tree blob at 9d400000
Booting using the fdt blob at 0x9d400000
Loading Device Tree to 00000000fd628000, end 00000000fd676fff ... OK
Working FDT set to fd628000
/bus@5a000000/dma-controller@5a1f0000, 57852
/bus@5a000000/dma-controller@5a9f0000, 59084
/bus@59000000/dma-controller@591f0000, 23492
/bus@59000000/dma-controller@599f0000, 24844
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.6.84-7.2.0-devel (oe-user@oe-host) (aarch64-tdx-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Mon Mar 31 08:47:48 UTC 2025
[ 0.000000] KASLR disabled due to lack of seed
[ 0.000000] Machine model: Toradex Apalis iMX8QP V1.1 on Apalis Evaluation Board
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000c0000000, size 960 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000000c0000000..0x00000000fbffffff (983040 KiB) map reusable linux,cma
[ 0.000000] OF: reserved mem: 0x0000000084000000..0x0000000085ffffff (32768 KiB) nomap non-reusable decoder-boot@84000000
I’m currently on Tezi 5.7.6 which is still working.
