Test Flash Colibri T30
Hello!
How is it possible to test the flash memory in the Colibri T30 kit in a Windows Embedded Compact system? Or another way?
As far as I know, the number of overwrites on a memory module is limited. How is it possible to check how many more overwrites it is possible to produce in flash-memory?
Thank you
You can install Linux (Flashing Linux from Windows - Toradex Tegra based Modules) and then get some data about flash as described here - eMMC (Linux) | Toradex Developer Center
If I understand correctly, I can test the allocated flash-memory area for Linux. But not all memory. Do I understand correctly that i’ll need to reinstall the entire system on Linux, test memory, and then return WINCE7 back?
Yes, you are correct.
