I have a question about installing Tensorflow Lite on TorizonCore with Verdin iMX8MM V1.1 and Dahlia Carrier Board V1.1B. When installing Dockerfile following the document “Torizon Sample: Image Classification with Tensorflow Lite | Toradex Developer Center”, I have a error " tflite_runtime-2.1.0.post1-cp38-cp38-linux_aarch64.whl is not a supported wheel on this platform." . Therefore, can we resolve this error?
Thank you so much for your reply.
Minh-Toan.
[+] Building 353.2s (10/13)
=> [internal] load build definition from Dockerfile 0.1s
=> => transferring dockerfile: 1.15kB 0.0s
=> [internal] load .dockerignore 0.1s
=> => transferring context: 2B 0.0s
=> [internal] load metadata for docker.io/torizon/debian:2-bullseye 3.4s
=> [auth] torizon/debian:pull token for registry-1.docker.io 0.0s
=> [internal] load build context 0.1s
=> => transferring context: 365.78kB 0.1s
=> [1/8] FROM docker.io/torizon/debian:2-bullseye@sha256:bde8dad15360c86832ebcd90ed0f769996cd77abc7f2cb45b289fd81203a30db 0.6s
=> => resolve docker.io/torizon/debian:2-bullseye@sha256:bde8dad15360c86832ebcd90ed0f769996cd77abc7f2cb45b289fd81203a30db 0.0s
=> => sha256:bde8dad15360c86832ebcd90ed0f769996cd77abc7f2cb45b289fd81203a30db 799B / 799B 0.0s
=> => sha256:3148838eedcf5713617f1797c53cbaf36568bff11c4df286e78a5bb0a334772b 2.40kB / 2.40kB 0.0s
=> => sha256:84f558ea2bbe4fef0735336fa6f6ad4ba7ac79eefc368f78f45926606333f8fa 6.99kB / 6.99kB 0.0s
=> [2/8] WORKDIR /home/torizon 0.1s
=> [3/8] RUN apt-get -y update && apt-get install -y python3 python3-dev python3-numpy python3-pil python3-pip python3-setuptools python3-wheel 272.1s
=> [4/8] RUN apt-get -y update && apt-get install -y wget unzip && apt-get clean && apt-get autoremove 53.4s
=> ERROR [5/8] RUN wget https://dl.google.com/coral/python/tflite_runtime-2.1.0.post1-cp38-cp38-linux_aarch64.whl && pip3 install tflite_runtime-* && rm tflite 23.2s
[5/8] RUN wget https://dl.google.com/coral/python/tflite_runtime-2.1.0.post1-cp38-cp38-linux_aarch64.whl && pip3 install tflite_runtime-* && rm tflite_runtime-*:
#9 0.751 --2021-09-24 14:02:25-- https://dl.google.com/coral/python/tflite_runtime-2.1.0.post1-cp38-cp38-linux_aarch64.whl
#9 0.922 Resolving dl.google.com (dl.google.com)… 142.250.179.110, 2a00:1450:4007:818::200e
#9 1.024 Connecting to dl.google.com (dl.google.com)|142.250.179.110|:443… connected.
#9 1.375 HTTP request sent, awaiting response… 200 OK
#9 1.528 Length: 1959576 (1.9M) [application/octet-stream]
#9 1.535 Saving to: ‘tflite_runtime-2.1.0.post1-cp38-cp38-linux_aarch64.whl’
#9 1.539
#9 1.539 0K … … … … … 2% 421K 4s
#9 1.659 50K … … … … … 5% 668K 4s
#9 1.732 100K … … … … … 7% 272K 4s
#9 1.916 150K … … … … … 10% 458K 4s
#9 2.025 200K … … … … … 13% 579K 4s
#9 2.115 250K … … … … … 15% 418K 4s
#9 2.229 300K … … … … … 18% 350K 4s
#9 2.372 350K … … … … … 20% 797K 3s
#9 2.435 400K … … … … … 23% 591K 3s
#9 2.519 450K … … … … … 26% 651K 3s
#9 2.603 500K … … … … … 28% 439K 3s
#9 2.712 550K … … … … … 31% 364K 3s
#9 2.847 600K … … … … … 33% 626K 3s
#9 2.927 650K … … … … … 36% 660K 3s
#9 3.014 700K … … … … … 39% 413K 2s
#9 3.124 750K … … … … … 41% 567K 2s
#9 3.211 800K … … … … … 44% 362K 2s
#9 3.351 850K … … … … … 47% 332K 2s
#9 3.502 900K … … … … … 49% 250K 2s
#9 3.701 950K … … … … … 52% 292K 2s
#9 3.890 1000K … … … … … 54% 286K 2s
#9 4.047 1050K … … … … … 57% 290K 2s
#9 4.218 1100K … … … … … 60% 109K 2s
#9 4.680 1150K … … … … … 62% 1.38M 2s
#9 4.717 1200K … … … … … 65% 947K 2s
#9 4.767 1250K … … … … … 67% 420K 2s
#9 4.886 1300K … … … … … 70% 465K 1s
#9 4.993 1350K … … … … … 73% 445K 1s
#9 5.106 1400K … … … … … 75% 512K 1s
#9 5.203 1450K … … … … … 78% 380K 1s
#9 5.335 1500K … … … … … 80% 333K 1s
#9 5.485 1550K … … … … … 83% 315K 1s
#9 5.671 1600K … … … … … 86% 385K 1s
#9 5.774 1650K … … … … … 88% 222K 1s
#9 6.000 1700K … … … … … 91% 1.84M 0s
#9 6.032 1750K … … … … … 94% 1.26M 0s
#9 6.065 1800K … … … … … 96% 192K 0s
#9 6.326 1850K … … … … … 99% 824K 0s
#9 6.387 1900K … … 100% 1.53M=4.9s
#9 6.397
#9 6.404 2021-09-24 14:02:31 (394 KB/s) - ‘tflite_runtime-2.1.0.post1-cp38-cp38-linux_aarch64.whl’ saved [1959576/1959576]
#9 6.404
#9 22.88 ERROR: tflite_runtime-2.1.0.post1-cp38-cp38-linux_aarch64.whl is not a supported wheel on this platform.
executor failed running [/bin/sh -c wget https://dl.google.com/coral/python/tflite_runtime-2.1.0.post1-cp38-cp38-linux_${PKG_ARCH}.whl && pip3 install tflite_runtime-* && rm tflite_runtime-*]: exit code: 1
