I previously inquired about Tensorflow Lite model loading error.
I want to do object detection using the object detection api.
I was unable to convert and load a saved_model from sensorflow2 to Ttflite using BSP5.4 and TensorflowLite 2.3.1.
SSD MobileNet v2 320x320
Tensorflow1 models could be converted to tflite and loaded. ssd_mobilenet_v1_quantized_coco
Why is this?
I am attaching the source code of the conversion, the source code of the execution, and log. convert.py (1.9 KB) log.txt (642 Bytes) test.py (864 Bytes)
Dear @developer0916 , are you using Verdin iMX8M Plus, right? Because the initial post you mentioned used Apalis iMX8 that doesn’t have NPU.
EDIT: Nevermind, just read the log. We are checking but I’m reading here and there and I’m not 100% sure if model conversion from TensorFlow2 is supported as TensorFlow(1). Do you know?
Their manual is very well done.
I think we too need to create a manual for AI.
There is a demand for it.
I am in the process of doing some research for that.
