I’m trying to follow the steps on these pages to run the example code on an Apalis IMX8QM WB IT:
I’m running bitbake with the reference minimal image.
I’ve removed onnxruntime since I will only use tensorflow-lite.
There’s an execution error with tensorflow-lite: do_compile().
I’m getting the following error :
ERROR: Task (/home/user1/oe-core2/build/../layers/meta-ml/recipes-libraries/tensorflow-lite/tensorflow-lite_2.8.0.bb:do_compile) failed with exit code ’
Everything else seems to compile just fine, tensorflow-lite is the only one giving an error.
In the error log, there are two more things -
- “Error: selected processor does not support `fmla v16.8h,v20.8h,v0.h[0]'” in …/oe-core2/build/tmp/work/cortexa72-cortexa53-tdx-linux/tensorflow-lite/2.8.0-r0/build/xnnpack/src/f16-gemm/gen/1x8-minmax-aarch64-neonfp16arith-ld64.S
I have limited the number of bitbake threads to 5 to reduce RAM usage.
How do I fix this error, since I think tensorflow-lite is correctly downloading the required files and the issue is only with the compilation.
In addition, I have a few questions :
- Since the steps are given for the Verdin board, is there anything I need to change in the procedure followed?
- Is it even possible to run bitbake for the tdx-reference-minimal-image? I do not require all the components present in the multimedia image and just want to test the example code on the page. The complete multimedia image will take a long time to build.
- Is it possible to build without onnxruntime, pytorch, and deepview-RT?
The PC specs are : Ubuntu 20.04.5 LTS 64 bit, 16 GB RAM, 12th Gen Intel® Core™ i7-12700 × 20
