today I always get an error when I try to build a custom image with a docker-compose file. It works without docker-compose and also worked last week. Going back and forward to an older/newer version of tcb didn’t help.
Since it worked last week, I did clean all my local docker images and updated some local tools, but I’d expect that this has no impact as tcb is container based.
The error log is:
2024-08-19 15:32:00,245 - torizon.tcbuilder.backend.deploy - INFO - Pulling OSTree with ref tcbuilder-20240819153154 from local archive repository...
2024-08-19 15:32:00,245 - torizon.tcbuilder.backend.deploy - INFO - Commit checksum: 00b4f4d16384701b9e5b06c412555a4555c41ef62f8ba5de12703a7bce8572cd
2024-08-19 15:32:00,246 - torizon.tcbuilder.backend.deploy - INFO - TorizonCore Version: 6.7.0+build.18-tcbuilder.20240819153159
2024-08-19 15:32:00,246 - torizon.tcbuilder.backend.deploy - INFO - Default kernel arguments: quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3
2024-08-19 15:32:00,246 - torizon.tcbuilder.backend.ostree - DEBUG - Pulling from local repository /storage/ostree-archive commit checksum 00b4f4d16384701b9e5b06c412555a4555c41ef62f8ba5de12703a7bce8572cd
1050 metadata, 9446 content objects imported; 583.2 MB content written
2024-08-19 15:32:08,358 - torizon.tcbuilder.backend.deploy - INFO - Pulling done.
2024-08-19 15:32:08,359 - torizon.tcbuilder.backend.deploy - INFO - Deploying OSTree with checksum 00b4f4d16384701b9e5b06c412555a4555c41ef62f8ba5de12703a7bce8572cd
2024-08-19 15:32:08,362 - torizon.tcbuilder.backend.deploy - DEBUG - Deploying revision 00b4f4d16384701b9e5b06c412555a4555c41ef62f8ba5de12703a7bce8572cd
2024-08-19 15:32:09,458 - torizon.tcbuilder.backend.deploy - INFO - Bootloader found in unpacked image: U-Boot
2024-08-19 15:32:09,459 - torizon.tcbuilder.backend.deploy - DEBUG - Write deployment for revision 00b4f4d16384701b9e5b06c412555a4555c41ef62f8ba5de12703a7bce8572cd
2024-08-19 15:32:10,336 - torizon.tcbuilder.backend.deploy - INFO - Deploying done.
2024-08-19 15:32:10,337 - torizon.tcbuilder.backend.deploy - INFO - Copy files not under OSTree control from original deployment.
2024-08-19 15:32:10,362 - torizon.tcbuilder.backend.deploy - INFO - Packing rootfs...
2024-08-19 15:32:10,367 - torizon.tcbuilder.backend.deploy - DEBUG - Running tar command: tar --xattrs '--xattrs-include=*' -cf /workdir/exivoip_0.0.2/torizon-core-docker-verdin-imx8mp.ota.tar -S -C /deploy -p .
2024-08-19 15:32:11,404 - torizon.tcbuilder.backend.deploy - DEBUG - Running compress command: zstd --rm /workdir/exivoip_0.0.2/torizon-core-docker-verdin-imx8mp.ota.tar
2024-08-19 15:32:16,447 - torizon.tcbuilder.backend.deploy - INFO - Packing rootfs done.
2024-08-19 15:32:16,447 - torizon.tcbuilder.backend.combine - INFO - Updating TorizonCore image in place.
2024-08-19 15:32:16,447 - torizon.tezi.image - DEBUG - No 'filelist' present in image configuration.
2024-08-19 15:32:16,447 - torizon.tezi.image - DEBUG - Reading json_data[key], value 'TorizonCore'
2024-08-19 15:32:16,447 - torizon.tezi.image - DEBUG - Writing json_data[key] = 'TorizonCore'
2024-08-19 15:32:16,448 - torizon.tezi.image - DEBUG - Reading json_data[key], value '6.7.0+build.18'
2024-08-19 15:32:16,448 - torizon.tezi.image - DEBUG - Writing json_data[key] = '6.7.0+build.18.modified'
2024-08-19 15:32:16,448 - torizon.tezi.image - DEBUG - Writing json_data[key] = '2024-08-19'
2024-08-19 15:32:16,548 - torizon.tezi.image - DEBUG - Reading json_data[key], value '6.7.0+build.18.modified'
2024-08-19 15:32:16,550 - torizon.tcbuilder.cli.build - INFO - Bundling images to directory bundle_20240819153216_550143.tmp
2024-08-19 15:32:16,550 - docker.utils.config - DEBUG - Trying paths: ['/root/.docker/config.json', '/root/.dockercfg']
2024-08-19 15:32:16,550 - docker.utils.config - DEBUG - No config file found
2024-08-19 15:32:16,551 - docker.utils.config - DEBUG - Trying paths: ['/root/.docker/config.json', '/root/.dockercfg']
2024-08-19 15:32:16,551 - docker.utils.config - DEBUG - No config file found
2024-08-19 15:32:16,848 - torizon.tcbuilder.cli.build - DEBUG - Removing temporary bundle directory bundle_20240819153216_550143.tmp
2024-08-19 15:32:16,848 - torizon.tcbuilder.cli.build - INFO - Removing output directory 'exivoip_0.0.2' due to build errors
2024-08-19 15:32:16,944 - root - CRITICAL - An unexpected Exception occurred. Please provide the following stack trace to
the Toradex TorizonCore support team:
2024-08-19 15:32:17,254 - root - ERROR - Traceback (most recent call last):
File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 793, in urlopen
response = self._make_request(
File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 496, in _make_request
conn.request(
File "/usr/local/lib/python3.9/dist-packages/urllib3/connection.py", line 400, in request
self.endheaders()
File "/usr/lib/python3.9/http/client.py", line 1250, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/lib/python3.9/http/client.py", line 1010, in _send_output
self.send(msg)
File "/usr/lib/python3.9/http/client.py", line 950, in send
self.connect()
File "/usr/local/lib/python3.9/dist-packages/docker/transport/unixconn.py", line 27, in connect
sock.connect(self.unix_socket)
PermissionError: [Errno 13] Permission denied
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.9/dist-packages/requests/adapters.py", line 486, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 847, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.9/dist-packages/urllib3/util/retry.py", line 470, in increment
raise reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.9/dist-packages/urllib3/util/util.py", line 38, in reraise
raise value.with_traceback(tb)
conn.request(
self.endheaders()
self.send(msg)
self.connect()
urllib3.exceptions.ProtocolError: ('Connection aborted.', PermissionError(13, 'Permission denied'))
File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 214, in _retrieve_server_version
return self.version(api_version=False)["ApiVersion"]
File "/usr/local/lib/python3.9/dist-packages/docker/api/daemon.py", line 181, in version
return self._result(self._get(url), json=True)
File "/usr/local/lib/python3.9/dist-packages/docker/utils/decorators.py", line 46, in inner
return f(self, *args, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 237, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File "/usr/local/lib/python3.9/dist-packages/requests/sessions.py", line 602, in get
return self.request("GET", url, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/requests/sessions.py", line 589, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.9/dist-packages/requests/sessions.py", line 703, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/requests/adapters.py", line 501, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', PermissionError(13, 'Permission denied'))
File "/builder/torizoncore-builder", line 222, in <module>
mainargs.func(mainargs)
File "/builder/tcbuilder/cli/build.py", line 592, in do_build
build(args.config_fname, args.storage_directory,
File "/builder/tcbuilder/cli/build.py", line 578, in build
raise exc
File "/builder/tcbuilder/cli/build.py", line 563, in build
handle_output_section(
File "/builder/tcbuilder/cli/build.py", line 308, in handle_output_section
handle_easy_installer_output(tezi_props, storage_dir, union_params)
File "/builder/tcbuilder/cli/build.py", line 380, in handle_easy_installer_output
handle_bundle_output(
File "/builder/tcbuilder/cli/build.py", line 436, in handle_bundle_output
"host_workdir": common.get_host_workdir()[0],
File "/builder/tcbuilder/backend/common.py", line 496, in get_host_workdir
docker_client = DockerClient.from_env()
File "/usr/local/lib/python3.9/dist-packages/docker/client.py", line 96, in from_env
return cls(
File "/usr/local/lib/python3.9/dist-packages/docker/client.py", line 45, in __init__
self.api = APIClient(*args, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 197, in __init__
self._version = self._retrieve_server_version()
File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 221, in _retrieve_server_version
raise DockerException(
docker.errors.DockerException: Error while fetching server API version: ('Connection aborted.', PermissionError(13, 'Permission denied'))
