Yes, our schedule is very tide. Actually we already has customer related complaints regarding this issue.
Would it be possible to get an update with only the fixed part early? Some sort of intermediate update?
Will the fix require a complete image updated?
Because that mean new installation of application firmware, calibration data and configuration at our customer, that has stall problems.
Sorry, yes of course it is 2017. I can not promise we can provide you an update of a single dll, but we will be able to build you an pre-release image once we have a fix ready in case single DLLs are not enough.
As mentioned above may be a complete image update is required. There are some drivers that can not be replaced in a built image.
We are using T20 (WIN CE7 Image Version 1.4) and 10.1 inch resistive 4 wire touch screen and facing same problem on 20+ units in production please guide to resolve.
I will share some contact details with you privately. In the mean time we will setup up a long term test with the I2C test application we wrote on our side, so far we run the tests only for a few hours. <<<<<-
Dear @chilaya
In your previous post you mention We are using T20 (WIN CE7…
while you stated in your initial question, that you use Colibri T30 and WEC2013. Can you please clarify?
Regards, Andy
