Hello
I built my own image upon BSP 2.2. Before we were still on BSP version 1.4. There I could build my own BSP without problem and it booted normaly.
Using now BSP V2.2 I’m no longer able to compile a bootable image. It always crashes during the loading of the filesystem. The output on the serial output shows the following:
Toradex Bootloader 2.2 for Tegra Built Dec 7 2018 15:05:43
Press [SPACE] to enter Bootloader Menu
Colibri T20 512MB 1.2A Serial: 4822467
RAM: 512 MB, CarveOut: 64 MB
Locating kernel image in flash...Done(1186)
Decompressing IMAGE(22349667, 44091304) from FLASH(0) to RAM(16000)...Done(503ms)
Jumping to image at 0x80016000...
Toradex Windows CE 7.0 2.2 for Tegra Built Dec 7 2018 15:05:21
INFO:OALLogSetZones: dpCurSettings.ulZoneMask: 0xb
L2 cache enabled
MainMemoryEndAddress adjusted from 0x9F000000 to 0x9C000000
Main Phys Mem: 0x00000000:0x1BFFFFFF
Carveout Phys: 0x1C000000:0x1FFFFFFF
Cold boot selected
DeviceId................. Tegra_4822467
pArgs->flags............. 0x0
pArgs->devLoc.IfcType.... 0
pArgs->devLoc.LogicalLoc. 0x0
pArgs->devLoc.PhysicalLoc 0x0
pArgs->devLoc.Pin........ 0
pArgs->ip4address........ 0.0.0.0
WARN: OALKitlInit: KITL Disabled
-OALKitlStart(rc = 1)
SMP: Active CPUs = 2
Loading ResourceManager...
Chip Id: 0x20 (Handheld SOC) Major: 0x1 Minor: 0x4 SKU: 0x8
Speedo: CPU: 304 (Corner: 1), Core: 200 (Corner: 2)
NVRM Initialized shmoo database
PllClocks(Mhz): X=1000, M=666, C=600, P=216, A=24.576
SysClocks(Mhz): CPU=1000, AVP=240, SysBus=240, Mem=333, EMem=666
GraphicClocks(Mhz): Host=108, 3D=111, 2D=111, Epp=111, Mpe=111, Vde=240
Done Loading ResourceManager (57 ms)
Loading FlashFileSystem(eMMC)...
Failed(0) Loading FlashFileSystem(eMMC) (0 ms)
Loading FlashFileSystem(NAND)...
Micron M71M PS:4KB BS:256KB DS:1024MB BCH16 ECC
INFO: TotalBlocks = 4096, FreeBlocks = 179
BBs: 0
No TAT bad block found.
No TT bad block found.
Done Loading FlashFileSystem(NAND) (221 ms)
Exception 'Data Abort' (0x4): Thread-Id=00520002(pth=a2802cf8), Proc-Id=00400002(pprc=82a945e0) 'NK.EXE', VM-active=00400002(pprc=82a945e0) 'NK.EXE'
PC=8005be24(NK.EXE+0x00045e24) RA=800323c4(NK.EXE+0x0001c3c4) SP=a68fe5b8, BVA=00000020
When I connect the debugger I get the following crash dump:
NK!8005be24()
NK!800323c4()
NK!80032e6c()
NK!80035c38()
KERNEL!OEMIoControl(unsigned long 0x00000004, void * 0x00000000, unsigned long 0x8009b0e0, void * 0x00000000, unsigned long 0x00000004, unsigned long * 0x00000000) line 153
KERNEL!KernelIoctl(unsigned long 0x00000004, void * 0x00000000, unsigned long 0x00000004, void * 0xefe66a70, unsigned long 0x00000004, unsigned long * 0x00000000) line 999 + 76 bytes
K.COREDLL!xxx_KernelIoControl(unsigned long 0x00000004, void * 0x00000000, unsigned long 0x00040000, void * 0x00000001, unsigned long 0x00000004, unsigned long * 0x00000000) line 1726
FILESYS!InitUserHives() line 1251
FILESYS!prgInitHiveRegistry(int 0xefe67d80, unsigned short * 0x00000004) line 1356
FILESYS!DoGeneralInit(unsigned short * 0xefe67d80) line 2133 + 12 bytes
FILESYS!FileSysMain(HINSTANCE__ * 0x00000000) line 2670 + 12 bytes
K.COREDLL!ThreadBaseFunc(unsigned long (void *)* 0xf100add0, void * 0x008b0003) line 1240
00000004()
I really don’t see where I’m missing something.
Thanks for any help.
