We are currently testing the T30 and T20 for battery life considerations. We have our pins setup and they work for all the peripherals we are using (I2C, SPI, UART, etc…) on both the T30 and T20.
However, there is one part that is being flaky, and that is the SD Card. On the T30 test, it always mounts correctly and can be used. When we put the T20 in, the SD Card is never mounted. The card detect pin (SODIMM 43) correctly changes to polarity 0 when inserted, and polarity 1 when taken out. Also, we use the same pins for both the T20 and T30 for the SD Card
The registry looks like this:
SodimmCardDetect = 43
CardDetectPol = 0
SdioInstance = 4 (2 if T30)
The only thing that is different between the T20 and T30 that I see is that the T20 has 4 extra pins defined for data4 - data7. I assume this is for high speed transfers for the SD, where the T30 only has the 4 data pins.
Additional note, once every 10 bootups or so, the SD card will show on the T20 as mounted. However, you cannot write to it or access it. After taking the SD card out, it will no longer show on subsequent times I plug it back in.
Is there any way to troubleshoot the driver on load of the SD card, or any way to query information about it’s state?
Tried both manually entering all sodimm pins in the registry as well as trying SdioInstance as well as referenced in the OP.
I did get some extra output on the debug interface. This is what it says as i eject then insert the SD card:
SDHCDIndicateSlotStateChange(DeviceEjected)
SDHCDIndicateSlotStateChange(DeviceInserted)
NvDdkSdioSetClockFrequency: Requested: 100 KHz, Actual: 101 KHz
I dug up an old carrier board and put in a stock T20 on version 2.1b2
After setting up the SDIO in registry (detect, polarity, instance #4) and rebooting, the SD card shows and I can read & write from it. I also did a T30 and it worked as well when changing the instance to #2. This is what I expect from our own board
Ok, I will take another look at it. Do you know of any possible differences between T30 and T20 for SD card? pins are same, polarity and detect are same, only difference I see is instance #. Different pullup values perhaps?
