edwaugh
              1
              Hi @andrecurvello.tx,
On the v1.0b Verdin IMX8MM boards I was able to read the cpu frequency using the files in:
/sys/devices/system/cpu/cpufreq/cpuX/cpufreq
But these don’t seem to be present having moved to v1.1a hardware. Could it be a configuration problem somewhere?
These files are useful as they also allow me to set the governor for the processor.
Ed
              Hi @edwaugh,
Could you test it with TorizonCore 5.2.0 (the latest nightly) to see if it’s working there?
André Curvello
                edwaugh
              3
              Sure, or I might see if @gauravks  has time to try. Does it work for you?
              Yes, that’s OK for me.
Any updates on that, @gauravks ?
