Dear Community.
I am testing a Colibri T30 in a Iris board and I am using the latest release from Toradex (actually discovered it on custom BSP based on this release but the problem occurs on a clean Toradex release as well).
I came across a problem with eMMC and suspend/resume to/from LP1. Upon resume it always fails to restore eMMC functionality and eventually re-mounts rootfs read-only but even then just produces a lot of errors. A log is attached below.
Thoughts?
.---O---.
| | .-. o o
| | | __ | ---'| '--.| .-'| | |
The Angstrom Distribution colibri-t30 ttyS0
Angstrom v2015.12 - Kernel 3.1.10-V2.6b2+g34c5824
Colibri_T30_LinuxImageV2.6_20160331
colibri-t30 login: root
Last login: Thu Mar 31 16:11:15 UTC 2016 on ttyS0
root@colibri-t30:~# echo "+15" > /sys/class/rtc/rtc1/wakealarm && echo mem > /sys/power/state
[ 74.462312] PM: Syncing filesystems ... done.
[ 74.731498] tegradc tegradc.0: switching framebuffer to 640x480
[ 74.738695] tegradc tegradc.0: Calculated sync href=0 vref=1
[ 74.738721] tegradc tegradc.0: using mode 640x480 pclk=25175000 href=0 vref=1
[ 74.800078] Tegra emc suspend: enabled bridge.emc
[ 74.804982] Tegra cpufreq suspend: setting frequency to 620000 kHz
[ 74.813518] Freezing user space processes ... (elapsed 0.01 seconds) done.
[ 74.833690] Freezing remaining freezable tasks ... (elapsed 0.01 seconds) done.
[ 74.854511] [mmc]:mmc_queue_suspend:354 mmc0: blk_stop_queue start
[ 74.860837] [mmc]:mmc_queue_suspend:354 mmc0: blk_stop_queue start
[ 74.867191] [mmc]:mmc_queue_suspend:354 mmc0: blk_stop_queue start
[ 74.873580] tegra_pwm tegra_pwm.3: pwm_disable called on disabled PWM
[ 74.880183] tegra_pwm tegra_pwm.2: pwm_disable called on disabled PWM
[ 74.886808] tegra_pwm tegra_pwm.1: pwm_disable called on disabled PWM
[ 74.893593] alarm_suspend(e6b47000, 2)
[ 74.900734] tegradc tegradc.1: suspend
[ 74.904647] tegradc tegradc.0: suspend
[ 74.908783] mpe mpe: suspend status: 0
[ 74.912792] isp isp: suspend status: 0
[ 74.916747] gr2d gr2d: suspend status: 0
[ 74.920876] gr3d gr3d: suspend status: 0
[ 74.925565] host1x host1x: suspend status: 0
[ 74.929959] [mmc]:sdhci_pltfm_suspend:203 mmc1: ++
[ 74.934903] [mmc]:sdhci_pltfm_suspend:218 mmc1: --
[ 74.939822] [mmc]:sdhci_pltfm_suspend:203 mmc0: ++
[ 74.958356] [mmc]:tegra_sdhci_suspend:885 mmc0: pull up data pin
[ 74.965776] [mmc]:sdhci_pltfm_suspend:218 mmc0: --
[ 74.973615] PM: suspend of devices complete after 119.348 msecs
[ 74.980613] PM: late suspend of devices complete after 0.938 msecs
[ 74.986958] Disabling non-boot CPUs ...
[ 74.993652] Wake[31-0] level=0x10012
[ 74.999149] Tegra3 wake[63-32] level=0x780
[ 75.005127] Wake[31-0] enable=0x1050102
[ 75.010805] Tegra3 wake[63-32] enable=0x700
[ 75.016799] Entering suspend state LP1
[ 75.022356] partition ve is left on before suspend
[ 75.022356] partition vde is left on before suspend
[ 75.022356] partition heg is left on before suspend
[ 75.022434] Exited suspend state LP1
[ 75.027702] legacy wake status=0x0
[ 75.032855] tegra3 wake status=0x0
[ 75.038050] Suspended for 13.828 seconds
[ 75.044554] PM: early resume of devices complete after 0.629 msecs
[ 75.060786] [mmc]:sdhci_pltfm_resume:229 mmc0: ++
[ 75.067686] [mmc]:tegra_sdhci_resume:946 mmc0: disable data pin
[ 75.145983] [mmc]:sdhci_pltfm_resume:242 mmc0: --
[ 75.152500] [mmc]:sdhci_pltfm_resume:229 mmc1: ++
[ 75.167025] [mmc]:sdhci_pltfm_resume:242 mmc1: --
[ 75.173483] host1x host1x: resuming
[ 75.195972] gr3d gr3d: resuming
[ 75.200880] gr2d gr2d: resuming
[ 75.205736] isp isp: resuming
[ 75.216005] mpe mpe: resuming
[ 75.220729] tegradc tegradc.0: resume
[ 75.240931] tegradc tegradc.1: resume
[ 75.316549] tegradc tegradc.1: using mode 0x0 pclk=0 href=0 vref=0
[ 75.336808] alarm_resume(e6b47000)
[ 75.341956] tegra_pwm tegra_pwm.1: pwm_disable called on disabled PWM
[ 75.350199] tegra_pwm tegra_pwm.2: pwm_disable called on disabled PWM
[ 75.358348] tegra_pwm tegra_pwm.3: pwm_disable called on disabled PWM
[ 75.366511] [mmc]:mmc_queue_resume:375 mmc0: blk_start_queue start
[ 75.374379] [mmc]:mmc_queue_resume:375 mmc0: blk_start_queue start
[ 75.382217] [mmc]:mmc_queue_resume:375 mmc0: blk_start_queue start
[ 75.390168] PM: resume of devices complete after 337.103 msecs
[ 75.397921] Restarting tasks ...
[ 75.401466] usb 1-1: USB disconnect, device number 2
[ 75.417079] done.
[ 75.421177] Tegra cpufreq resume: restoring frequency to 475000 kHz
[ 75.434867] eth0: unregister 'asix' usb-tegra-ehci.1-1, ASIX AX88772B USB 2.0 Ethernet
[ 75.451254] Tegra emc resume: disabled bridge.emc
[ 75.479664] mmcblk0: error -110 transferring data, sector 287240, nr 2, cmd response 0x900, card status 0xc00
root@colibri-t30:~# [ 75.580923] end_request: I/O error, dev mmcblk0, sector 287240
[ 75.586782] Buffer I/O error on device mmcblk0p2, logical block 123140
[ 75.593313] lost page write due to I/O error on mmcblk0p2
[ 75.677222] mmcblk0: error -110 transferring data, sector 287242, nr 2, cmd response 0x900, card status 0xc00
[ 75.697507] end_request: I/O error, dev mmcblk0, sector 287242
[ 75.703364] Buffer I/O error on device mmcblk0p2, logical block 123141
[ 75.709894] lost page write due to I/O error on mmcblk0p2
[ 75.766768] ADDRCONF(NETDEV_UP): dummy0: link is not ready
[ 75.772497] ADDRCONF(NETDEV_UP): sit0: link is not ready
[ 75.777913] ADDRCONF(NETDEV_UP): ip6tnl0: link is not ready
[ 75.783580] ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 75.836205] usb 1-1: new high speed USB device number 3 using tegra-ehci
[ 75.997687] usb 1-1: New USB device found, idVendor=0b95, idProduct=772b
[ 76.004492] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 76.011664] usb 1-1: Product: AX88772B
[ 76.015505] usb 1-1: Manufacturer: ASIX Elec. Corp.
[ 76.020487] usb 1-1: SerialNumber: 000001
[ 76.029322] ASIX USB Ethernet Adapter:v4.17.0 20:55:27 Mar 30 2016
[ 76.029336] http://www.asix.com.tw
[ 76.798057] eth%d: status ep1in, 8 bytes period 11
[ 76.821015] eth0: register 'asix' at usb-tegra-ehci.1-1, ASIX AX88772B USB 2.0 Ethernet, 00:14:2d:2a:77:c3
[ 76.831979] eth0: rxqlen 0 --> 5
[ 76.902884] eth0: ax88772b - Link status is: 0
[ 76.947206] mmcblk0: error -110 transferring data, sector 287244, nr 2, cmd response 0x900, card status 0xc00
[ 76.960013] end_request: I/O error, dev mmcblk0, sector 287244
[ 76.965872] Buffer I/O error on device mmcblk0p2, logical block 123142
[ 76.972402] lost page write due to I/O error on mmcblk0p2
[ 77.011924] mmcblk0: error -110 transferring data, sector 287246, nr 2, cmd response 0x900, card status 0xc00
[ 77.048913] end_request: I/O error, dev mmcblk0, sector 287246
[ 77.054776] Buffer I/O error on device mmcblk0p2, logical block 123143
[ 77.061307] lost page write due to I/O error on mmcblk0p2
[ 77.087600] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 78.571983] eth0: ax88772b - Link status is: 1
[ 78.577824] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 79.693254] mmcblk0: error -110 transferring data, sector 423484, nr 64, cmd response 0x900, card status 0xc00
[ 79.703330] end_request: I/O error, dev mmcblk0, sector 423484
[ 79.709184] end_request: I/O error, dev mmcblk0, sector 423486
[ 79.715033] end_request: I/O error, dev mmcblk0, sector 423488
[ 79.720877] end_request: I/O error, dev mmcblk0, sector 423490
[ 79.726721] end_request: I/O error, dev mmcblk0, sector 423492
[ 79.732564] end_request: I/O error, dev mmcblk0, sector 423494
[ 79.738407] end_request: I/O error, dev mmcblk0, sector 423496
[ 79.744249] end_request: I/O error, dev mmcblk0, sector 423498
[ 79.750092] end_request: I/O error, dev mmcblk0, sector 423500
[ 79.755935] end_request: I/O error, dev mmcblk0, sector 423502
[ 79.761777] end_request: I/O error, dev mmcblk0, sector 423504
[ 79.767619] end_request: I/O error, dev mmcblk0, sector 423506
[ 79.773462] end_request: I/O error, dev mmcblk0, sector 423508
[ 79.779304] end_request: I/O error, dev mmcblk0, sector 423510
[ 79.785146] end_request: I/O error, dev mmcblk0, sector 423512
[ 79.790988] end_request: I/O error, dev mmcblk0, sector 423514
[ 79.796830] end_request: I/O error, dev mmcblk0, sector 423516
[ 79.802671] end_request: I/O error, dev mmcblk0, sector 423518
[ 79.808511] end_request: I/O error, dev mmcblk0, sector 423520
[ 79.814353] end_request: I/O error, dev mmcblk0, sector 423522
[ 79.820194] end_request: I/O error, dev mmcblk0, sector 423524
[ 79.826035] end_request: I/O error, dev mmcblk0, sector 423526
[ 79.831876] end_request: I/O error, dev mmcblk0, sector 423528
[ 79.837717] end_request: I/O error, dev mmcblk0, sector 423530
[ 79.843559] end_request: I/O error, dev mmcblk0, sector 423532
[ 79.849432] end_request: I/O error, dev mmcblk0, sector 423534
[ 79.855274] end_request: I/O error, dev mmcblk0, sector 423536
[ 79.861115] end_request: I/O error, dev mmcblk0, sector 423538
[ 79.866956] end_request: I/O error, dev mmcblk0, sector 423540
[ 79.872796] end_request: I/O error, dev mmcblk0, sector 423542
[ 79.878635] end_request: I/O error, dev mmcblk0, sector 423544
[ 79.884476] end_request: I/O error, dev mmcblk0, sector 423546
[ 79.891134] Aborting journal on device mmcblk0p2.
[ 79.912061] mmcblk0: error -110 transferring data, sector 418308, nr 2, cmd response 0x900, card status 0xc00
[ 79.922020] end_request: I/O error, dev mmcblk0, sector 418308
[ 79.927871] Buffer I/O error on device mmcblk0p2, logical block 188674
[ 79.934401] lost page write due to I/O error on mmcblk0p2
[ 79.939879] JBD: I/O error detected when updating journal superblock for mmcblk0p2.
[ 80.380477] EXT3-fs (mmcblk0p2): error: ext3_journal_start_sb: Detected aborted journal
[ 80.417705] EXT3-fs (mmcblk0p2): error: remounting filesystem read-only
root@colibri-t30:~#
