Feature Request:
- [High Priority] Support USB-Ethernet adapters (e.g. Realtek RTL8153 chip and Asix AX88179 are extremely common, as well as some new 2.5G adapters)
- [Medium Priority] Support Wi-Fi in TEZI (connection would only be at runtime and not saved)
Context:
- One of the advantages of TEZI is the ability to quickly install latest images via a network connection. However, it depends on the availability of a native Ethernet port.
- For boards without Ethernet ports, this would open up new capabilities for developers and certain manufacturing workflows.
- The complexity to enable these drivers should be quite straight forward.
