$ sudo dpkg --add-architecture i386 command not found
I am on step 1 of “Compiling examples from command line”
I tried to execute the
but it can not find the command.
Running the command from root and dpkg is not installed. Using the recovery I installed the system again and the issue wasn’t resolved.
Would you please advise on how to resolve the issue?
Thanks,
Are you trying to run this command on Colibry system? This is for you host machine setup for cross build. Please follow steps described here - Embedded Linux Application Development Overview | Toradex Developer Center
Thank you. It works.
Glad it helped. Thanks for using our products.
