I am beginner in Toradex kit.
I use imx6D processor 512 MB model.
I can try to update my system but sudo command not work. and I also try to install another software but I get this error:
sudo command not found.
please suggest me a right way to how to use command in terminal???
What exact hardware (module and carrier board) and software versions of things are you talking about?
BTW: In our regular Embedded Linux BSP’s one usually is already logged in as root so there is no point in sudo really.
Thank you for your reply,
hardware description given below:
Apalis iMX6 Dual 512MB
also attached link :
NXP/Freescale i.MX 6 Computer on Module - Apalis iMX6 - Übersicht
Thanks for this Information.
Which command did you use to install the software?
Please read the following to install the software package you need.
