I am stuck in Torizon after installing from Easy Installer. Any tips or suggestions are much appreciated.
I cannot get back to booting the Easy Installer from SD card. I want to get rid of Torizon and install a different image.
What I Did:
- installed Angstrom
LXDE via Easy Installer. This worked fine. - Copied Easy Installer to SD
Card - Boot Easy Installer from SD card, using u-boot terminal, run distro_bootcmd
- Installed Qt Demo image via Easy Installer. Demo worked fine.
- Boot Easy Installer from SD cars, using u-boot terminal, run distro_bootcmd
- Attempt Install Torizon via Easy Installer.
System hangs at Torizon splash screen after reboot. The Torizon splash screen displays with a static progress-bar or text-entry at bottom (I do not know what it is)
After installing Torizon, attempts to boot from Easy Installer SD card fail:
Using serial terminal connected to X27, press space key, then run distro_bootcmd
NAND: 512 MiB
MMC: FSL_SDHC: 0
Loading Environment from NAND... OK
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX6ULL 512MB Wi-Fi / BT IT V1.0A, Serial# 03073253
Net: eth1: ethernet@020b4000
Hit any key to stop autoboot: 1 0
Colibri iMX6ULL # run distro_bootcmd
run distro_bootcmd
ubi0: default fastmap pool size: 200
ubi0: default fastmap WL pool size: 100
ubi0: attaching mtd5
ubi0: scanning is finished
ubi0: attached mtd5 (name "ubi", size 508 MiB)
ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
ubi0: good PEBs: 4060, bad PEBs: 4, corrupted PEBs: 0
ubi0: user volume: 2, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 9/4, WL threshold: 4096, image sequence number: 1174212782
ubi0: available PEBs: 0, total reserved PEBs: 4060, PEBs reserved for bad PEB handling: 76
Scanning ubi 0:...
Found U-Boot script /boot.scr
2427 bytes read in 3 ms (790 KiB/s)
## Executing script at 87000000
422 bytes read in 44 ms (8.8 KiB/s)
7672320 bytes read in 6806 ms (1.1 MiB/s)
3255570 bytes read in 2926 ms (1.1 MiB/s)
Kernel image @ 0x81000000 [ 0x000000 - 0x751200 ]
ERROR: Did not find a cmdline Flattened Device Tree
Starting kernel ...
If I remove SD card then reboot, I am stuck back in Torizon splash screen:
NAND: 512 MiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Scanning ubi 0:...
42364 bytes read in 45 ms (918.9 KiB/s)
7672320 bytes read in 6804 ms (1.1 MiB/s)
3255570 bytes read in 2922 ms (1.1 MiB/s)
## Flattened Device Tree blob at 82100000
Booting using the fdt blob at 0x82100000
Using Device Tree in place at 82100000, end 8210d57b
Updating MTD partitions...
Starting kernel ...
[ 2.612266] UBI error: cannot open mtd UBI, error -2
[ 2.620185] rtc-ds1307 0-0068: hctosys: unable to read the hardware clock
Starting version 243+
root '/dev/ubi0_1' doesn't exist or does not contain a /dev.
I could not seem to get anywhere using iMX Recovery Mode
https://developer.toradex.com/knowledge-base/imx-recovery-mode#colibri-imx6ull
Any tips or directions are much appreciated.
-Ed
