Hi, I come from here: Colibri VF50/61 UART 3 and 4 not working after custom DTB - Technical Support - Toradex Community
After I’ve succesfully updated my DTB in order to activate UART 3 and 4, I’m unable to load the newly compiled kernel. It just stays there, no error message. I’ve tried leaving it over an hour without any change. Flash to the NAND worked fine and Uboot boots correctly.
I’ve followed the tutorial Build From Source Code Documentation Overview | Toradex Developer Center, and according to KConfig the kernel is 4.4.39. I’ve tried changing a couple of options in the configurations disabling all fs except ext2/3/4, compiling with the default config, and nothing seems to change.
Any help is appreciated.
Álvaro.
