On the Apalis TK1 running the BSP v2.7b3 the serial console has by default echo turned off. And I’m unable to set it on using stty /dev/ttyS0 echo
This command fails. Is there any way around it?
I didn’t see this with the previous BSPs.
Isn’t it stty -F /dev/ttyS0 echo
Nope. Still not working.
root@tegra-ubuntu:/home/ubuntu# stty: /dev/ttyS0: unable to perform all requested operations
Hi I tried the command
sudo stty -F /dev/ttyS0 echo
with the Linux tegra-ubuntu 3.10.40-2.7.5 and BSP 2.7b3. It is working fine.
Which version of Ubuntu are u using?
