Hello
I see a strange behavior when I try to communicate with rs485 under python. Here is my test program:
import fcntl
import serial
import struct
print("pyserial version", serial.VERSION)
ser = serial.Serial(port="/dev/ttymxc0",
baudrate=4800,
parity=serial.PARITY_NONE,
bytesize=8,
stopbits=1,
timeout=5)
serial_rs485 = struct.pack('hhhhhhhh', 3, 0, 0, 0, 0, 0, 0, 0)
fcntl.ioctl(ser.fileno(), 0x542F, serial_rs485) # enable rs485
ser.flush()
wrdata = b"0123401234\n"
print(">> %r" % wrdata)
n = ser.write(wrdata)
print("%d bytes written" % n)
bytesToRead = len(wrdata) * 2
answer = ser.read(bytesToRead)
print("%d bytes received" % len(answer))
print("<< %r" % answer)
ser.close()
The RS485 interface is connected but there is no response from the other side.
As long as I send less than 32 bytes I see my own echo. For example
pyserial version 3.5
>> b'012340123401234012340123401234\n'
31 bytes written
31 bytes received
<< b'012340123401234012340123401234\n'
If i send 32 bytes or more there is no echo, which is ok from my point of view:
>> b'0123401234012340123401234012340\n'
32 bytes written
0 bytes received
<< b''
If I connect a device on the remote side that sends back a response and increments each byte by the value 5, i see both the echo and the response from the remote side (if less than 32 bytes):
python3 test2.py
31 bytes written
62 bytes received
<< b'012340123401234012340123401234\n567895678956789567895678956789\n'
If I send 32 or more bytes for this case, everything looks good:
python3 test2.py
32 bytes written
32 bytes received
<< b'5678956789567895678956789567895\n'
A similar c-program works.
Edit: This is not true, also with the c-program the “echo” exists.
Can anyone help?
Beste regards
René
sudo tdx-info
Software summary
Bootloader: U-Boot
Kernel version: 5.15.129-6.5.0+git.6f8fd49366db #1-TorizonCore SMP PREEMPT Fri Dec 22 11:15:52 UTC 2023
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/fe091cbe7b665ff6d9d5d618cb20c42c90c242fffeaceccf204eacd186b2f597/0
Distro name: NAME="TorizonCore"
Distro version: VERSION_ID=6.5.0-build.8
Distro variant: VARIANT="Docker"
Hostname: v80labor
Hardware info
HW model: Toradex Verdin iMX8M Plus on Mallow Board
Toradex version: 0070 V1.1A
Serial number: 15128074
Processor arch: aarch64
